Originally Posted by
isaac65
Yup, you guys were right. The brake fluid is low. What type do you guys recommend? Is it ok to mix fluid brands? I've never had to do this before... lol
Thanks!
WARNING, WARNING, WARNING
If you top off the reservoir, the next time you change the brake pads and compress the pistons in the caliper's, you will pump paint eating brake fluid all over the engine compartment. The reservoir fluid level will go down as the pads wear, this is normal
