"you should take some closer pics so i can see what you came up with..."
LOL - I can't believe you said that with a straight face.![]()
Nice job, way to innovate using what you have!
Now, I can't help but ask, your lights look like they point up a little, can you adjust them? I had the same problem with the light bar my friend made. Originally, there was nothing but the posts and the frame, and when mounted, my lights pointed up at 45°. The Hella lights are adjustable, but not that much. So, I had to have him make a triangular mounting to make the posts stick out straight. Hard to explain, but you can see the flat stock in this picture used to make the main frame of the mounting bar sit at 90° to the ground.
I need to come up with and idea for reverse lights next...
god i wish i could get some money to get some lights worked out like this but they are pretty low on my list of stuff to do...with HID's i dont really NEED them, but i think they would be helpful....
sliders and skidplates are first on the list...
Yeah, the HIDs really are nice. My buddy told me I can get HID ballast kits for my Hellas which will make them even brighter than they are now. Which would be nice, but at $35 each I can wait, since I need 4. Eventually I will do this though. They just make a huge difference when driving at night. The stock headlights don't cut it.
yup, the stock headlight is ok, but the HID's make them amazing...
i actually found some reasonably priced driving lights that come with the HID set up...gonna pick up a set for myself to mount to the front of my VX...
I bought the kit off of ebay from hong kong, was a little under 50 dollars, got here in 4 days, and they are amazing. Its a dual beam kit, but I could not get the halogen brights to work, but you don't need them anyway, the HIDs are brighter. Their customer service was great, there is a slight wiring mod you have to do, on their plugs, not the factory, otherwise, its plug and play. Everything fit perfect. There is a one year warranty on the bulbs, but even if you had to buy a whole new kit, its cheaper than silverstars.
Let the flaming begin...![]()
http://cgi.ebay.com/4X4-JEEP-SUV-CRV...hippingPayment
$150 is a good price shipped....
[SIGPIC][/SIGPIC]...
I am MORE than interested! This is my email: snowwolf83@hotmail.com. You can also private message me on this site as I'm doing everything I can to get my VX fixed without pumping anymore money than I need to in it!
I have a question though: if you look at my last post in the VX Troubleshooting thread, I completely forgot to mention the problem with my fuse board. The guy that previously owned my vehicle had ghetto-rigged a LOT of stuff to the fuse board and it wasn't until I went through an entire box of fuses that I decided to figure out what the hell was wrong. Apparently the previous owner rigged a wire that connects the "trunk popper" button to the same fuse that runs the internal and head lights.
Point is, I want to add those lights to the top of my VX, but I don't want to screw up my fuse board more than it has already been screwed with. What do you suggest?
-VXRaven![]()
I never like the idea of even touching the fuse board for any reason.
If i add roof lights to my VX (which i'll deffinetly do) i'll just run a independent wiring from the battery + terminal,run a - wire to ground or chassis,add a in-line fuse to the the + wire,run it the wiring thru the firewall & add a switch to the dash,that's all.
Isn't necessary to mess with the fuse board at all to add roof lights.
I added a nice set of blue LED light nozzles without touching the fuse board.
I just attached the nozzle's + wire to the left + head light wire,add a 0.5 amps in-line fuse to it & run the - wire to ground,the LED's lits up only when my head lights are on which are barely use.
I'll posting few pics this week end in my gallery's album.
Dakar was just the begining.
for those curious/ who want to recreate it here is a CAD model of my light rack setup
Green is the yakima loadwarrior
Yellow are yakima round bars attached to my roof rails
Red is the square tube mounts that support the light rack
Blue is the light rack itself
yellow/blue are the lights themselves
orange is the yakima connectors i used
