Results 1 to 14 of 14
Thread: Abs Code 35
Threaded View
johnny010 Abs Code 35 01/06/2009, 09:36 PM
johnny010 Bump 01/07/2009, 02:11 PM
Ldub Was there water in the ravine? 01/07/2009, 02:13 PM
nfpgasmask What I am confused about is... 01/07/2009, 02:57 PM
Ldub http://www.vehicross.info/foru... 01/07/2009, 03:09 PM
    Abs Code 35
    So I replaced the abs module that had given me code 43 (means replace the unit).
    I grabbed one out of a 1999 Trooper that had 4 wheel disc brakes. Anyway, after install/bleed brakes etc...I tested it key on/off 5 times all good. Did five starts (key on/off) all good. Then test drove it, all good. Stopped for 20 minutes, Then test drove again (key on/off again), and still all good.
    The abs light is BACK ON. Got home, checked and I am getting code 35 which is a Valve Relay (shorted or disconnected coil wiring B-9).
    Anyone know what to tell me to fix it?
    Thanks,
    JM
  1. Engine Code
    Last Post: 01/13/2010, 10:21 PM
  2. TOD throwing code 13
    Last Post: 02/10/2007, 01:54 PM
  3. fault code
    By patrick cooper in forum VX Troubleshooting...
    Last Post: 09/27/2006, 01:18 PM
  4. PO 440 - Code
    Last Post: 01/03/2006, 08:21 PM
  5. Cel Code 405?????
    By Mr. I-MAN in forum VX Modifications...
    Last Post: 09/10/2004, 08:13 AM
