Okay, so I read the 'how to' on checking the codes. I'm not sure what he means by 'a warning light will be displayed'?
In the TOC example video the check light flashes back and forth.
For the abs, when I've jumpered the dtc, the abs light starts flashing. Is this the warning light?
How many times do I count the warning light (if the abs light blinking is it)? It seems to flash quite a bit.
Thanks,
jm
