Does anyone know if the VX's suspension parts are similar to the Axiom, Trooper, Amego, etc.? Thanks. Please direct responses here or to ronaldmal21@aol.com. THanks for your time
We share a lot of parts with the Trooper RS (short wheelbase 2 door trooper).
Is the rear axle indentical w/limited slip? That could broaden my choices to locate an axle or diff. for my ring & pinion whine.......![]()
Larry S.
99 Astral Silver VX (176k)
91 Porsche 928 S4 (73k)
Shoot "BigSwede" a PM. He is an RS owner and can probably answer that question. FYI there are even fewer RS out there than VX's.
Will do Billy, thanx!!
Check out http://www.myisuzuparts.com to see what parts are the same.
In the Vehicross introduction video, Mike says, "Now, although the front and rear suspension are based on the Trooper, parts are not interchangeable because of different spring rates".
Mark
If I remember correctly, no one uses our exact match. We have a 4.30 ratio. RS troopers use a 4.77 in the 1st gen, 4.56 like all second gen troopers post 92. I think the 1st gen amigo also uses 4.56. You might have some luck with an old pickup though. I think there were a couple that used a 4.30 ratio. Stock 4.30 diffs will be hard to come by. If it is just a diff whine and you need to change out the thrid member, might be cheaper/easier to change out both diffs at the same time to a 4.56 ratio. Those are easy to come by.
Ryan Christiansen
Trooper Skid Plates, OME 912's, Stric9 Sliders, Load Warrior with extension, Apline sub in rear door, Apline front speakers, Alpine head unit, Definity Dakota MT 285/75 R16, Aussie Lockers Front and Rear, 4.77 gears and Warn Manual Hubs.http://picasaweb.google.com/RyanVehiX
I read a long time ago that the front anti-sway bar was bigger than the Trooper's as well... even bigger than the sway bar that comes with the Calmini lift kit.
As I was driving today, I saw an Axiom. That may be your solution, no that they are common. They too had a 4.30 ratio I think and a rear 12 bolt, so that may be a doner axle.
1987 AMC Eagle: stock
I'd say some parts, especially front suspension have the same numbers with Rodeo. So, you never know if it's directly replaceable from Trooper or from Rodeo, or both, or unique.
I'm also using this site to find crossing:
http://www.isuzuparts.com/part_number.html
They have newer part numbers for obsoleted parts, while myisuzuparts lists original numbers at manufacture time.
Does anyone know if the suspension in the VX is similar to the Axiom, trooper or Hombre? Thanks
I merged your threads from an earlier time. You got quite a few answers.
Scott / moncha.com
