Originally Posted by
VXD959
Thank you Leon R. The wheels I was planning on ordering online say "hub bore 106.10", which is 4.19". I called and they told me that it won't fit the 4.25" (108mm) hub.
Will a larger wheel hub be a problem (110mm to 125mm)?
The ~3" is the popular Chevy size that doesn't work on VX.
4.25" (108mm) definitely works and 4.17" (106mm) might still work. I wouldn't rule it out just yet.
Edit: judging by this thread: http://www.vehicross.info/forums/sho...3188&highlight
Both 108mm and 106mm should work
96 Eclipse Spyder GSX (already turbo, AWD swap)
93 Eagle Summit AWD (4G63 turbo swaps)
