The thread for AFTERMARKET WHEELS and TIRES for the VX.
Please post pictures if you have upgraded your VX with AFTERMARKET WHEELS and TIRES.
So we can have a reference of what looks good!
So please post a picture along with these specs.
Rims are: (brand/size/offset)
Tires are: (brand/size/overall diameter)
Stock height or Lifted (if Lifted, please list Lift specs)
Note any trimming.
Let me know if I need to change any specs.
Thanks for everyone's help.
rickshaw
Rims and Tires Part 2
Rims and Tires Part 3
Rims and Tires Part 4
Rims and Tires Part 5
Rims and Tires Part 6
Rims and Tires Part 7
Rims and Tires Part 8
Rims and Tires Part 9
Rims and Tires Part 10
Rims and Tires Part 11
Rims and Tires Part 12
Rims and Tires Part 13
Useful Links:
Wheel Spec Wiki Thread
Before and After Thread
Tire Size Calculator
Wheel Offset Calculator
Wheel/Tire Comparer
Offset to Backspacing Chart
How to Post a Picture
Stock VX wheel & Tire Specs for reference
245/60-18 Bridgestone Dueler (Diameter 29.6 in)
18x7 and 16x7 (38mm positive offset) 6X139.7mm or 6x5.5" Bolt Pattern
Rims & Tires Part 1
rickshaw
Rims are KMC XD Monster 18x9 (Offset +18mm) (Back Spacing 5.71in) (Center Bore 106.25mm)
Tires are Nitto Terra Grapplers 285/60/18 (Diameter 31.38 in)
(Lifted) OME 913's, 2" torsion bar crank
Rickshaw's Mod Thread
More info on the 913's
Jay Dunford
Rims are Mickey Thompson Classic Locks in 16x8
Tires are Goodyear MTR 305/70/16. (Diameter 32.8 in)
(Lifted) OME 912's + 1" poly spacers for a 3-1/2" lift in the rear; crank the torision bars + 1/4" ball joint spacers to level the front.
Kenny
Rims are 17x8 Enkei RT6 rims (0 offset, 4.5 Backspace)
Tires are Mickey Thompson BAJA MTZ 265/70/17(Diameter 31.6 in)
(Lifted)
Kenny's Tire Thread
Pho2gr4
Rims are 16x8 American Racing Teflon Chambers wheels. ("0" Offset 4.5" Backspace)
Tires are 275/70/16 Yokohama's (Diameter 31.2 in)
(Lifted) OME 913's
Dumke
Rims are American Racing ATX Thugs 18x9 ("0" Offset 5" Backspace)
Tires are Nitto Terra Grapplers 285/65/18 (Diameter 32.6 in)
(Lifted) Independent 4x premium lift kit
Dumke's Wheels & Tires Thread
Zues
Rims are BBS Moda R7 18x8.5 (Offset "0")
Tires are 275/65/18 Hankook Dynapro mud tires (Diameter 32.1 in)
(Lifted)
LittleBeast
Rims are Zinik Z26 20x8.5 (Offset +15mm)
Tires are 33x12.5 Nitto Mud Grapplers (Diameter 32.95 in)
(Lifted) OME 912 springs, ball joint flip, and torsion crank
LittleBeast's Build Up Thread
Ldub
Rims are 20x8" Centerline Tomahawk Rapid (polished)
Tires are 33-12.50x20" Nitto Mud Grapplers
(Lifted) Lift: 3-4" (OME 919's, 1" coil spacer & T-bar crank)
taylorRichie
Rims are KMC Rockstar 20X8.5 (Offset +10mm)
(Lifted) OME912 Coils, +1" Spacer, Torsion Crank, Lots o' Trimmin'
taylorRichie's Build Up Thread
Rowhard
Rims are MKW M18 18x8.5 (Offset +18)
Tires are Toyo Open Country AT 285/60R18 (Diameter 32.6 in)
(Stock height) Bars cranked to get some extra clearance plus trimming
JoFotoz
Rims are Pro Comp "Street Lock" 16x8 MT Classic Lock simulate #MT 468412
Tires are 33x11.50x16 Nitto Mud Grapplers
(Lifted) 3 inch Calmini lift.
nfpgasmask
Rims are 16" American Racing Chambers w/Teflon
Part number: AR3985-6883 (0 offset/4.5 on the backside)
Tires are 265 75/R16 (Diameter 30.7 in) BFG Mud Terrains
(Lifted)
nfpgasmask's Rims Thread
CrnCnn
Rims are Crager Soft 8 16x8 (5" backspace +12mm offset)
Tires are BFGoodrich All-Terrain T/A® KO 245/75/16 (Diameter 30.5 in)
(Lifted) OME 912's
CrnCnn's Build Up Thread
Jolly Roger VX'er
Rims are 16"X 8" American Racing "Breaker" chromed aluminum wheels w/ 12mm of offset
Tires are 265-75-r16 (32" tall) Green Diamond Icelander M/T's (Severe Snow Rated)
(Lifted) Two-inch rear coil spring spacers from Independent4X.com plus 8 cranks each side on front Torsion bars.
Swordy
Rims are 16" (need more info)
Tires are 33x12.50x16's Parnelli Jones dirt gripz (Diameter 33.3)
(Lifted) 3" Calmini lift
Daver
Rims are OZ Crono 4x4 16x8 (Offset +10)
Tires are BFGoodrich All-Terrain T/A® KO 265/70-16 (Diameter 30.6 in)
(Stock height) Trimed the front fender a little bit.
More Info Here
tom4bren
Rims are (need more info)
Tires are 33x12.50 Goodyear Wrangler
(Lifted)
dstruction
Rims are Dante 20 inch wheels
Tires are 36 inch super swamper IROKs
(Lifted)
Cyrk
Rims are 18x8 Borbet CW3 (Chrome
Tires are Toyo Proxes S/T Tires 255/55/18 (Diameter 29.0 in)
(Stock height)
For more pics on see post #23
BaM*BaM
Rims are Silver 18x8 Borbet CW3
Tires are 35x12.50x18 BFGoodrich Mud-Terrain T/A
(Lifted)
