Results 1 to 9 of 9
Thread: New VX tonight - need help with 4 issues
    Regarding the brakes...with the vehicle off, pressing the brake pedal, it makes no noise (thought it might be a bushing - guess not).
    With the vehicle on in park, when pressing the pedal it makes the noise 30% of the time when pressing in and out. When in drive, it makes the noise 100% of the time but it sounds like it is coming from the pedal inside the cab. High pitched eeeeeeerrrrrrr (like Eeyore the blue donkey) It only make the noise when pushing the pedal in.
    The brake fluid res. is way overfilled btw. I see that can cause the ABS light to come on.
    The service records show veh serviced at 26K miles (for the 30K), and ABS was one thing that was checked (doesn't say if it was on at the time or not).
    Veh has 28K miles on it now.
    So what about the rodeo ABS module? Will it work?
    Sep 2004
    1999, Astral Silver, VX, 0938
    Welcome to the Forum...Johnny if you bought the VX below, and it's from a dealer it's a no brainer...Take it back and have them make it right. Enjoy it and most of all...DRIVE IT...
    http://cgi.ebay.com/ebaymotors/Isuzu...spagenameZWDVW
    I got the price low enough that I agreed to it as is knowing the issues. No gripes with them. I knew if it came down to it the abs module would be expensive; however, most of the Toyotas that have a light come on just need a wheel speed sensor. Should have read a bit more since it seems the Isuzu's need the abs module.
    I have a mechanic that owes me a huge favor, so I'm sure the noise from the pedal will be fixed this week. I'll have the abs light diagnosed IF it doesn't go away once I put the right amount of fluid in it (over full). As for the picture below, it appears I will just have to buy another piece, and then spend the $50 on the window fix-its plus a retint.
    Then I'm sure a seal will go out...lol : )
    Anyone got a drivers side power assy for sale?
    Took out the extra brake fluid. The whinning noise from the pedal went away for about 2 hours but has come back sporadically.
    Unhooked the battery after correcting the fluid level to see if the abs light would go away..........nice dice.
    and read this.......
    "Used Isuzu Vehicross ABS Relays
    The ABS relay (or ABS controller) is the brain that controls your anti-lock braking system. If your ABS light has come on it may be time to replace your ABS relay because a malfunctioning ABS relay can compromise your safety.
    The ABS relay in your car is commonly found in a plastic protective box found under the hood or under the dashboard on the passenger side. There might also be an access panel that has to be removed under the dashboard to expose the controller
    When searching for a replacement ABS relay, be sure to provide the salvage yards with your Vehicle Identification Number (VIN). This will help to ensure that you receive the right used ABS relay unit for your particular vehicle.
    Replacing the ABS relay should be fairly easy since it's just a matter of swapping out your old controller for the one you've purchased.
    Find Used Isuzu Vehicross ABS Relays Fast!"
    At first is sounds like they are talking about the ABS module, but the bolded parts sounds like a relay only???
    kind of sounds like they could be talking about the abs computer.. which is located under the passenger seat.. from what ive heard, its not very often that the problem is there... they are definitely not talking about the abs module though, that is not just a simple swap out... well it is.. but you have to bleed the brakes afterwards. but replacing mine is what has had my abs light off for a month or two now after it had been on steady for almost a year
    discussed with a mechanic regarding my eeeeerrrrrr noise when pressing the brake pedal. after i took the brake fluid down to the correct level, the noise went away for 2 hours, but came back...
    te mechanic said right away, before i could finish, that the master cylinder is going out and needs to be replaced.....and i believe he may be right.
    will pull the eprom codes this week to find out about the abs issue. hopefully it turns out to be a wheel cylinder only.
  1. P1404 CEL tonight...
    By nfpgasmask in forum VX Troubleshooting...
    Last Post: 07/30/2014, 12:41 AM
  2. Ken Block on Top Gear tonight!
    Last Post: 02/08/2010, 02:52 PM
  3. Going out to the airport tonight.....
    By LittleBeast in forum VX Talk...
    Last Post: 05/01/2009, 04:37 PM
  4. Man muscles needed tonight!
    Last Post: 11/07/2008, 11:24 AM
  5. L.A. VXer's Tonight
    By Anita in forum Meets...
    Last Post: 11/30/2003, 01:13 PM
