Results 1 to 15 of 32
Thread: transmission help needed
    Thanked: 7
    Post
    Sounds like it very well may be the mode switch. Hard, even violent shifts both up and down occur when it goes out. Check also if your shifting display on the dash flickers oddly when you do shift. Sometimes it is more apparent when you drive the truck first thing. If you do a search on Mode Switch you will find tons of information. Here is just one link:
    http://www.vehicross.info/forums/sho...ht=mode+switch
    Good luck with your VX
    Anita
    2000 Ebony #263
    AnitaProtich.com
    1999 black vx
    is the mode switch the same as the neutral safty switch
    Thanked: 7
    To get a definitive answer I would recommend calling Merlin at St. Charles Isuzu. He deals with us continually and probably could answer your question. 1-800-727-8066
  1. Replies: 0
    Last Post: 11/18/2016, 04:46 PM
  2. help needed
    Last Post: 07/07/2012, 03:19 PM
  3. Help needed
    By Grok in forum VX Talk...
    Last Post: 01/10/2011, 11:42 AM
  4. Help needed.
    By igor_san in forum VX Modifications...
    Last Post: 08/11/2009, 07:25 AM
  5. Help is needed
    Last Post: 01/25/2007, 03:44 PM
