Well today i was just driving down the road and the check engine light and the transmission light cam on i have a 1999 vehicross i have a couple of questions.
1. How do u check the transmission fluid.
2. is a mode selector switch the same as the neutral safety switch.
it has a high idle when its in park and it shifts real hard in to the gears and out of them and it also acts like it wants to die like it has water in the gas or something right before all this happened i hit a big water hole that was in the road the alternator is new and so is the battery and help would be great thank u in advance
