Results 1 to 10 of 10
Thread: Taping down hood cladding?
    1999, Ironman, 1705
    the corner of the hood cladding by the passenger window is raised off of the hood... what tape do i use to stick it back to the hood?
    Thank you
    Aug 2006
    99, Silver, 1773
    Hummm??? The stock Hood insert is held in there with bolts, if that's what we are talking about. Other than that, there isn't any cladding on the hood?
    1999, Ironman, 1705
    Quote Originally Posted by Techy-D View Post
    well the corner of the hood insert is poping up, just the very corner, it looks like it had a 3m tape or something under... i guess its warpped? but it easily can be pushed down to the hood again so woulda 3m tape work or what would you all suggest using?
    Jan 2008
    1999 Astral Silver 0481
    Quote Originally Posted by killinformula View Post
    What i'll suggest you to do is to remove the under hood isolating cover,is the black sheet & see if there's any missing nuts
    Dakar was just the begining.
    2001 Proton VX #0690
    Note that the washer nozzles are also responsible for holding down the hood insert.
    Also, is it possible that the previous owner did tape over the hood? It should be a flat black, and might have a couple cracks in it... but I don't think it peels...
    Chances are, the adhesive holding the stud to the bottom of the insert has let loose, removal of the insert & a bit of JB Weld should fix you right up, just don't over tighten during re-assembly.
    Or, as stated earlier, you could be one nut short of complete insert restraint...
    Check my gallery for a solution most wouldn't touch with a ten foot whatchamacallit...
    BFS!:bwgr:
    **Big F'in Staplegun!**
    1999, Ironman, 1705
    looks like i will be taking it off this weekend.... its just those bolts and it comes off nice and easy right?
    Feb 2008
    1999, Astral Silver, VX, 1598
    check the downloads section for the full shop manual. I can only assume it has complete instructions on how to pop that sucker off.
    Yep, though some of those bolts are hard to see. And, as mentioned earlier, the washer squirters have to be removed too.
    While you have the insert off, take apart the drain tubes under the insert & clean them out too, they're under the leading edge of the insert...
    Just pull the hose off of the drain cup & clean it out with some warm water & a pipe cleaner or piece of wire.
    They will get clogged up again in about two weeks, but it's easy to do after you see how they go together.
    Also, give the hood under the insert a couple coats of wax.
  1. Looking for Hood Insert
    By jtirado in forum VX Talk...
    Last Post: 01/18/2016, 08:00 PM
  2. Looking for FRONT CLADDING, HOOD, BUMPER
    By highfall in forum VX Troubleshooting...
    Last Post: 03/20/2015, 06:03 AM
  3. Replies: 1
    Last Post: 04/09/2007, 07:43 AM
  4. Hood Scoop
    By Proton_Thang in forum VX Talk...
    Last Post: 10/05/2004, 08:19 AM
  5. Hood no release
    Last Post: 09/12/2004, 07:25 PM
