Well, what exactly happened? Are you feeling the brake pedal pulse back at you as you try to stop? Are you running stock brake pads or after market?
I feel the ABS pulse when it kicks in. Does not pull either way. Brakes feel normal, pedal feels firm and does not go to the floor. Each of the two noted incidents happened on either side of the recent brake service which included new pads and rotors. I did notice the brakes felt a bit stronger after the service, but just barely.
Just feels like ABS activates too easily, and once on, reduces braking effectiveness.
Anything else?
Thanks,
Tim
Hmm... kind of strange. ABS is normally triggered when a wheel locks up. Either one of your wheels is locking up before the others (brake force could be way out of balance and locking up one wheel way before the others, but that's unlikely), or the ABS unit is not operating correctly, or a wheel speed sensor is not working properly and tricking the ABS into activating.
Do you see any unusual behavior in the ToD lights?
My money is going on a faulty front wheel speed sensor...
