Originally Posted by
Triathlete
Those tires should fit just fine with very little trimming. I ran that size AT's before the lift. a few twists of the T-bars to take the rake out of the VX will make them fit even better. I would skip the spacers though. That will just put your tires into the cladding when turning since it makes your turning arc wider.
When he was stock, his was a 1999 with OEM 16" rims.
http://www.vehicross.info/forums/sho...threadid=14520
I just fit that size tire on a stock 2000 VehiCROSS but with custom 16" wheels (+10mm offset as opposed to +38mm for stock wheels) which made it harder for me than it would be for you since your wheels are tucked up under the fenderwelds and mine are out further towards the outer lip of wheel well.
