Results 1 to 15 of 46
Thread: Burning Oil?
    1999, Ebony Black, VX ,1976
    It is not so much the fault of the pcv valve as it is the fact that there is no baffle to stop the oil from being sucked from the valve cover. In other engines the failure of the pcv valve does not have the same affect as it does in the 3.5 . shawn
    1COOLVX
    May 2003
    Wink
    My own personal experience has taught me that there was a double-edged sword involved with oil consumption in my engine.
    The EGR Valve..if not properly recirculating exhaust gases back into the cylinders to be reburned (EGR=Exhaust Gas Recirculation) under normal operation, would lead to higher cylinder temps. Just like if you were to block it off and deny proper operation.
    When the EGR is functioning properly, it is "smothering" the cylinders with spent exhaust gas that is meant to be reburned for environmental sake and therefore not letting in a totally fresh air/fuel mixture during the intake stroke. In effect...it is lowering the efficiency of each cylinder. Make the EGR inoperable either through failure (ie.stuck closed) or physically blocking it off and the cylinder temps go up due to the more efficient combustion of a fresh air/fuel intake charge not being smothered by exhaust gasses fed into the cylinders through the intake by the EGR.
    Then...add in a malfunctioning PCV which leads to high crankcase pressure that "resists" the oil in the cylinder attempting to return back to the oil pan.
    Now that you have oil lingering around in the cylinders due to opposing pressure of a stuck PCV and higher cylinder temps due to a stuck EGR you get alot of oil burn-off during the combustion process.
    In short...My VX started using oil before I supercharged it at 30,000 miles; and after I cleaned out the EGR with oxgen sensor safe carb cleaner to remove the black carbon that was causing it to stick closed....and after I started changing the PCV at regular intervals to maintain proper operation....the oil usage dropped drastically to what I consider normal (approx. 1/4 quart in 3,000 mile oil change interval....sometimes less)
    I recommend cleaning the EGR @ 30,000 mile intervals...or replacing it if cleaning it doesn't free up a stuck valve. I recommend maintaining proper operation of the PCV.
    If there is an oil ring problem..it will only be exaggerated by the failures of either the EGR and/or the PCV systems....think of all this as a triangle...where you have control over 2 of the 3 legs.
    Jan 2008
    1999 Astral Silver 0481
    Oil loss
    Quote Originally Posted by Jolly Roger VX'er View Post
    I got to agree with you about this one,my mech told the same thing as you explained here.
    The PCV should be replace every oil change just for the sake of the engine.
    In february i'll have my VX's transmission,transfer case & differential fluids serviced & i'll probally have the EGR cleaned so make sure full performance is delivered
    Dakar was just the begining.
    This is all good as long as the pcv valve functions properly for 3000 miles. I had a brand new one malfunction and lost 2 qts of oil in the first 1000 miles After an oil change and pcv valve change. If I had not checked the oil level before leaving on a 3 hr trip to NH I would have had a seized motor.
    Also I would have to disagree with this statement:
    "Then...add in a malfunctioning PCV which leads to high crankcase pressure that "resists" the oil in the cylinder attempting to return back to the oil pan.
    Now that you have oil lingering around in the cylinders due to opposing pressure of a stuck PCV and higher cylinder temps due to a stuck EGR you get alot of oil burn-off during the combustion process."
    There should be no oil in the cylinder trying to return to the pan. Any oil that gets past the rings or is sucked in through the pcv valve will not return to the oil pan it gets burned. Or do you mean the oil in the crankcase below the piston on the cylinder wall ? shawn
    May 2003
    Quote Originally Posted by psychos2 View Post
    Absolutely true...if excessive enough gives you the tell-tell bluish smoke out the exhaust pipe (worn rings)
    Yes, I was meaning the oil in the crankcase below the piston on the cylinder wall that could be opposed by high crankcase pressure to return to the pan and be subjected to the high volitility (burn-off) of elevated cylinder temps due to malfunctioning EGR. Sorry, I should have stated it better than I did.
    looking for a vx
    Hi, car guy here, has anyone put in aftermarket pistons or tried to swap in the newer style piston from the 02 or 04 engine in hopes of solving this?
    Jan 2008
    Quote Originally Posted by ilya View Post
    HI Ilya !
    Absolutely ! many VX'ers had their engines rebuildt or completly replaced.
    I personally have no idea if aftermarket rings is a good deal to go for,however i'll suggest you to do some research & figured out two tips:
    COST AGAINS VALUE AGAINS QUALITY
    If a set of original OEM pistons from isuzu cost $ 350 & the aftermarket set cost $ 280 i'll try to put the other $ 70 & buy the original .....This is my quote
    Apr 2007
    2001, Proton #1238
    As far as I know it’s not the pistons or rings that’s causing the oil consumption problem.
  1. Hot Rim, Burning Smell
    Last Post: 12/23/2011, 01:35 PM
  2. Burning Man - Live
    By ZEUS in forum VX Talk...
    Last Post: 09/05/2009, 10:24 PM
  3. Burning Music to CD's....help
    Last Post: 04/22/2008, 03:29 PM
  4. Burning man, man...
    Last Post: 08/06/2007, 06:11 PM
