Has anyone seen this link and or have one if these intakes? Feedback or recommend another?
http://www.racinglab.com/weapon-r-dr...vehicross.html
Larry S.
99 Astral Silver VX (176k)
91 Porsche 928 S4 (73k)
It's kind of pricey don;t they ?
I wondering that can be the difference between this & K&N![]()
Dakar was just the begining.
Skeptical, skeptical. I REALLY would get a guarantee from the vendor for a return in case it doesn't fit. I have tried some "other" parts that are ideal for Honda that "claim" to work on the VX and did not.
Another little sumpin' to think about...
Even with a heat shield, (which, if made of metal, will eventually attain pretty close to under-hood temps.) you're still sucking warm under-hood air into your intake...
Heat soak also comes into play if the intake tube is made of metal...especially aluminium.
So most are still running the stock intake because most of these are ineffective, especially off-road and wet weather? Maybe just run a K&N direct factory replacement?
Will do, as always Larry, thanks!![]()
