Results 1 to 4 of 4
Thread: Fuel Tank Leaking ?
    1999, Ebony Black, VX ,1976
    Fuel Tank Leaking ?
    I have been having a gas smell around my vx. I looked at it this morning and there is fuel dripping from the cover under the tank. I could not get the cover off because my tools are at work. It is ethier the tank or something connected to the tank. Has anyone had issues with the tank leaking? shawn
    1COOLVX
    I found the leak it is the fuel sender on the front passenger side of the tank.
    2001, Dragon Green, 1342
    SO, were you able to repair it and if so how, just a re-torque
    I have not yet . I could not remove screws.I drained enough gas so it would stop leaking. I could not tell if it was the gasket or the part of the sender were the plug is. I will probably just get a new sender and replace it. Is St Charles still open for parts? shawn
  1. Help: How to Replace fuel lines going to the fuel rails.
  2. Gas tank
    By Pepino in forum VX Talk...
    Last Post: 03/27/2008, 03:39 PM
  3. Fuel Injectors and Fuel Pump
  4. Do fuel tank additives really make a difference?
    By Lease-V-cross in forum VX Talk...
    Last Post: 06/27/2004, 05:43 PM
  5. What's in That Tank?
    By chumone in forum VX Talk...
    Last Post: 04/26/2003, 09:03 PM
