I changed the oil tonight. Just like I always do, every 3000 miles. Except this time, my PCV valve was all goobery and there was a lot of oil that looked like it spooged up and out around the valve, which I have never seen happen before, and I usually change my PCV every, or every other oil change. The other weird thing, is that I drained my oil, just like normal, and for about the same amount of time, jacking up the passenger side to get as much out as possible. Typically, I can use one whole jug of Mobile-1 oil (5 quarts) and it fills me right up to the fill line on the dipstick, usually with a very little bit left in the jug. This time however, my VX took the whole jug, and there was nothing registering on the dipstick at all! I had to crack open another jug and add about another half quart I would estimate, and probably 3/4ths of a quart to get the oil to the fill line on the dipstick.
Now, the only thing, is that last Satuday I installed a brand new EGR. Could this have anything to do with this weirdness?
Thanks - Bart
