Several members in the past have mentioned severe bump steer (vehicle jumps to the side when encountering a significant bump at speed).
Several members in the past have indicated that their rear axle is shifted to the right (due to lift or for any other reason).
Question: If you experience bump steer with your VX, is your rear axle shifted?
Mine is not shifted and I don't experience bump steer. I'm just trying to figure out if a panhard rod drop shakle will help with this problem.
PS - how do you set up voting in this here poll???![]()
