so its finally time to replace that abs module.. dusted off the new unit thats been sitting on a shelf for the last year
but im not sure where to start... should i drain the brake fluid out of the vx first? (start the car, open the bleeder screws and let it drain) or can i remove the abs unit with the system still full then just bleed everything out later?
any tips?
