Help Reno VX owners,
I was recently told that I had a RF axle seal leak and T-case leak
800.00 bucks!! This seems a bit steep for about 80.00 bucks for parts.
Anywhere I can take it to other than the dealer?
T.
T.
Hey,
Well, we can certainly take a look for you and give you our "professional" opinion.Do you know where the leak is coming from? Is it from the fill or drain bolt? Or maybe from the seal? When was the last time you had a trans service performed? Give us your details.
Where have you been? Is this the first time you are on the forum? We are always looking for new members to join us here in Reno. Maybe you would be interested in meeting up with the group sometime for lunch or dinner and we could take a look at your truck.
Yo, This is my first time on the forum. I didnt event know it existed until I met
a VX owner in Sand City Ca. He gave me the scoop about the forum. He had a
2001 Firefox. A real beauty compared to my beater. Anyway I just took to it
Izuzu lithia where I always take it. I was told of the problem after an oil change
and coolant flush.
Welcome to the forum!!! You will find lots of useful info here as well as good company! Are you the one with the ski/board racks up top? I have seen a few silver VXes around town, one used to be parked all the time at the Men's Warehouse, and one in NW Reno I used to see a lot with ski gear up top.
Anyway, the trans/xfer case service is important. Have you ever had a full trans service done? This would mean dropping the pan and changing out the filter and putting a new gasket in place, as well as draining and refilling all fluids. I have done mine twice, and its not hard, just a little messy and I would designate a full afternoon to get it done. A would imagine a shop would charge around $800 for this service because it does take some time. If you have never done this, I would imagine you may have some rotting around the gasket that could cause a leak, or possibly a bad fill/drain bolt.
Another thing to think about, is if you have had your fluid drained and filled, the shop may have not done it properly. The trans is easy to over/under fill if you do not do it right. Both scenrios can be bad for your trans. How is shifting gears? Clunky or ok?
So was it Bren who you met in California?
http://www.vehicross.info/forums/showthread.php?t=14133
It's about time you showed up, Tom.
Welcome to the forum and I envy you being in the good hands of the Reno VX crowd up there.
Good luck with your project. It does sound like something you can do yourself with some beer and guidance. Take care, Bren.
Bren Workman
Gretna, NE
(C) 402-312-1992
Hey Bren, and everyone else on the forum. I guess I will get work done soon
before it cost me a lot more. Its funny that it took Bren to inform me about this
forum since I live in reno and have been honking and waving to all VX owners I
see. I live in Double Diamond and have a neighbor behind me that owns a dark
green VX. I've seen just about every VX in Reno There is someone out there
that has a double of mine. 99 silver with a yakima rack. Then there is the silver
lift with big *** tires. Never had the chance to actually talk to anyone
except Bren. But Im sure that will change now. One more thing. I have
always noticed when I stop at a light or whatever there's a kind of clunk
sound. Since this has been going on for years I assumed its normal....Is it?
Everything else is good other than the windows and oil consumption.
BTW- could the clunking sound possiby be the TOD engaging and
disengaging?
T Upp
PS I have a right door motor assembly for sell never used. Bought it thinking that was the problem. make offer.
Hey Tom,
Cool, you live down by me and CrnCnn. I live in south Reno also. We should meet up at the new Bully's sometime soon. I know the other guys will be down for dinner and few brewskies.
The clunk is normal for the most part, except it can be better or worse. To me, it sounds like you need a trans service, which I am sure we can help you with, that is, if you wanna save some money, get a little dirty and spend some quality time with the other VXers in town. It's actually an easy job when you have a couple helpers. After my first trans service, my shifting and clunking was WAY better. This is part of the VX that I think gets let go too long and too often, and mainly because our trans is a closed system and requires more work to get at.
I bet the Dragon you live by belongs to the lady who works at the post office off Mccabe Dr. I met her a few weeks ago. She has less than 20k on her clock!!!
We get together pretty often, and it would be really cool to add another VXer to the pack. I've been working on David (oldguywithgoodtaste) for a while too, he also has an Astral...
A 5 member meet-up would be sooooo sweet.
yep it clunks at start up. But after hearing about all the 99 engine failures I'm pretty lucky.....so far. 73K
Yes, and so far so good.
