hey guys and gals, i need help to find out what made my engine over heat really bad, what happend was i was going up a sand dune and it bottomed out and i had it on 4wd low, and i was pressing the gas hard, then i realized the engine temp... gauge went up to almost all the way. then i reversed and gave it like 2 mins and the gauge went all the way back to normal. now what i'm thinking is, did it happend cuz the sand was hot and it was bottomed out and reving the engine to go up, did that made it over heat cuz there was no air cooling the engine from the bottom plus the hot sand? what you guys think? or is there something else i should worry about? Thanx guys. Oh by the way, i just moved to Corpus Christi Texas, so it's hot over here as well.
