has anyone seen or heard of this? found it surfing the web.
thought i could help us pull some more ponys out of our engines. maybe even help the supercharged guys remap the ecu!:_drool: granted it is pretty expensive.
any input would be greatly appreciated.
AEM Universal EMS ECU
[30-1900U]
http://www.genuineperformance.net/images/aemems.jpg
The success of our Plug & Play EMS program created a demand for a universal unit, and AEM is proud to release its Universal Programmable EMS. AEM Universal Programmable Engine Management System adapts to any vehicle using the company flying lead wiring harness and sensors (sold separately). We are confident that this is the most versatile, powerful, and comprehensive universal engine management program available.
In addition the features found in our Plug & Play EMS, AEM Universal EMS also includes 10 independent, built-in peak & hold injector driver channels, direct drive ignition and dual wideband UEGO controllers. Peak & Hold injector drivers enable users to utilize low impedance injectors with a true 4/1 Peak & Hold injector drive circuit. The Direct Drive ignition feature allows users to drive a coil directly from the ECU without the need for an igniter or ignition module. A wideband UEGO controller is an essential tuning tool that provides a 0-5 signal for monitoring and tuning air/fuel ratios (AFR) on heavily modified high-performance engines.
Key features include:
Utilizes Windows software
Built-In Peak & Hold Injector Drivers
Built-In Direct Drive Ignition
Built-In Dual Wideband UEGO Controllers
10-Cylinder Sequential Fuel Injection
16 General Purpose Outputs
7 Definable Switch Inputs
Electronic Boost Control
Soft Cut Rev Limiters
Two-Step Launch Control
Fuel Table Automapping
Programmable Traction Control
Onboard 512kb Datalogger
Wet or Dry Nitrous Control
Definable Knock Control
Full Idle Control
$2,387.99
