Results 1 to 6 of 6
Thread: Quick question - where to mount stuff underdash?
    Jun 2003
    No VX anymore
    I'm ready to install my new camera / monitor setup, but I can't decide where to mount the relays - there seems to be an open space to the right of the steering wheel.
    Any recommended locations?
    May 2002
    2000, Proton Yellow, VX, 0584
    I mounted mine under the left foot well cover.. Just left of the brake pedal. Any where that you can get a solid mount should be good.. Beware though, they do make clicking noises.
    Scott / moncha.com
    Oct 2002
    There are a ton of spaces for mounting relays. Pop the lower dash pieces off and you'll see a few. Pop the side foot well trim pieces and you'll find some more. On the passenger side there's even a prexisting hole that you can mount the relay to and ground it at the same mounting point.
    Jun 2003
    No VX anymore
    Thanks - I mounted the relays near the factory relays by the driver's left footrest, behind the black plastic trim piece.
    The problem I'm having is finding a ground for wires in that area. Anything painted yellow is insulated, right? I don't see much bare metal back there.
    Oct 2002
    If you don't see any... make your own. There should be plenty there. Last time I looked while wiring up lights there were plenty. Use a test light or multimeter to find suitable grounds.
    May 2002
    THere is a very nice share point there in the same area that you mounted the relay. Just use a nice big ring or fork terminal and put it there.
  1. Just a quick question
    By dietz99vcross in forum VX Talk...
    Last Post: 03/20/2014, 07:30 AM
  2. Quick question
    By PontiacPureBred in forum VX Talk...
    Last Post: 09/14/2013, 04:42 AM
  3. Dash Cam mount with quick release...
    Last Post: 08/19/2006, 02:46 PM
  4. Quick BFG question
    By SRCHN in forum VX Talk...
    Last Post: 07/11/2006, 01:46 PM
  5. Quick question...
    By shoota77 in forum VX Troubleshooting...
    Last Post: 11/30/2005, 06:17 PM
