I talked about this once before, guess when Dino, aka Bandit was on the board. So will say it again, so,
insert 2 cents
The ABS module ain't much more then a shuttle valve, and if you don't lock them brakes up and use that shuttle valve, it does nothing but sit there and rust up since brake fluid is a big sponge for water.
When ever it rains or snows, I lock um up and get that valve jump'in and I ain't had any problem at all with my VX or other ABS equip't vehicles. I try and do this at least once a month.
remove 2 cents
