View Poll Results: has your abs pump/module made your abs light come on?
Voters
153. You may not vote on this poll
  • yes
    110 71.90%
  • no
    43 28.10%
Results 1 to 15 of 99
Thread: question and poll regarding abs module
    Nov 2003
    '99 Ironman 1405
    I was told to use a flat head screwdriver to depress a pin that would release the plug. Did you have to press a pin? Please describe where that pin is located. Was it near the top of the plug? Did you need a screwdriver and did you hold the screwdriver blade horizontally?
    I seem so close to resolving this issue without resorting to the sledgehammer nuclear option.
    Not sure exactly...just don't remember it being that hard.
    Shop manual doesn't even mention that connection.
    Nov 2003
    '99 Ironman 1405
    Well, I may just have to actually resort to Alltech to handle an easy fix that was too much for me, yet again. Good to know I'll be helping a tech's kids enjoy a bit merrier Christmas.
    I do okay when components are readily visible, but DIY projects requiring me to feel my way around are costly: minor scrapes, cuts, back strain, etc., plus lots and lots of wasted time. Really aggravating to be so close, but to get stumped by a simple plug. Had a similar experience replacing my stock flasher with a LED compatible one. Wasted lots of time, strained my back, etc., then ended up taking the VX to Alltech.
    Update: Sunday, 16 Nov 2014
    2:30 p.m. - Removed the small plug, undamaged, and removed 4 of the 6 screws. The lower left 2 are proving to be more challenging than anticipated. I can see where having the right tools would have made this task a breeze, such as appropriate length T20 screwdrivers/bits with a small ratchet wrench.
    Last edited by Bill Brown : 11/16/2014 at 02:38 PM Reason: Update: Sunday, 16 Nov 2014
    Oct 2009
    2001 Mica Green VCS 0403
    How did you get the plug out?
    Nov 2003
    '99 Ironman 1405
    Quote Originally Posted by soggybottomboyz View Post
    After successfully removing the plug I wondered how I could explain the simple action required. Used an angled flathead screwdriver that came with a furniture item I had assembled. Placed the blade horizontally inside the top of the plug receptacle. With very minimal light pressure, used the blade to push the top of the (plastic?) retaining clip outward, which immediately released the plug. Gravity dropped the plug from the receptacle. Very easy to do once you've done it.
  1. isuzu axiom intake module question
    By djvx in forum Chit-Chat ...
    Last Post: 12/24/2010, 05:46 PM
  2. ABS Module
    By haggisgood in forum VX Troubleshooting...
    Last Post: 02/19/2009, 01:25 PM
  3. ABS module, how much??!
    Last Post: 10/02/2008, 07:42 AM
  4. ABS module
    By WiSDoM in forum VX Troubleshooting...
    Last Post: 09/01/2007, 02:26 PM
  5. TOD Module
    By WiSDoM in forum VX Talk...
    Last Post: 06/30/2006, 09:26 AM
