Yes, this is what I did.
Just loosen it from the bracket and loosen the brakelines mounted on the fender well and the firewall. Be careful or you will break the plastic retainers that hold the brake lines in place.
Gently move it up, so as not to crimp any brake lines and remove the six torx screws and the black module. You would have already removed the two electrical connections. Mount the silver box back into the bracket.
I drove mine with the black box removed and it drove terrible when braking and turning in tight places like parking spots or getting into my garage.
Just be careful and you'll be fine...![]()
