View Poll Results: has your abs pump/module made your abs light come on?
Voters
153. You may not vote on this poll
  • yes
    110 71.90%
  • no
    43 28.10%
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 99
Thread: question and poll regarding abs module
    Here's the link we're we discussed all this in much more detail.
    http://www.vehicross.info/forums/sho...ht=durango+abs
    Since I talked to the guy several times, I'll make contact with him and explain it's the VX group again, and see if I can get him to the $69.
    Earl, hold on until I can reach him, and remind him of our several emails AND his confirmation that the charge was the same for the Trooper OR the VX.
    Thanks Sue.
    For anyone who has removed the electronics, but not the mechanics:
    How did you get enough slack in the brake lines to get the units apart without bending the lines?
    Love to do it this way so I won't need to bleed the brakes.
    Jul 2009
    As always, YOU ROCK SUE!!
    Vixer Fixer
    thank you good sir!
    x like a bazillion...
    Just in case you'd like to remove your ABS bulb whilst waiting for the new control module, here's a simple write up I did on the process.
    Jul 2009
    T4B to the rescue! Anybody wonder what makes this forum so great??
    Removed and shipped today...
    Thanks for all of the collective help...gotta love this forum!
    Received the part back today...
    Hooked it up and NO MORE LIGHT and the ABS works as it should. We got a few inches of snow this week and the shady part of my neighborhood was a great testing spot.
    I would recommend the service discussed in this thread to anyone wanting to get their ABS groove back on...
    Also as a note I did drive the VX with the electronic portion of the ABS removed and it was awful. Brakes locked up on tight turns ( think in/out of a parking space and riding the brake) and was very jerky...
    Nov 2012
    This is really strange to me. Shouldn't the braking performance be the same with a non-functioning ABS controller and no controller? They way I think it works is you apply force to the brake pedal providing hydraulic pressure to all four brake calipers. When wheel slippage is detected the ABS controller rapidly opens and closes the solenoid associated with that wheel effectively pulsing the hydraulic pressure to that caliper. Having the ABS controller removed should provide normal non-abs braking. Right? Could there be another issue with the brakes that M H VX is experiencing?
    There's no 'I' in denial.
    Jan 2010
    1999 Astral Silver
    Gear
    OK so about one month later and two weekends in conditions where ABS is actually helpful (snow / slush / ice) up at Tahoe ABS module repaired by ASI went bad again. I am sure they will fix it for me free but it takes time / money to pull it out and esoecially reinstall since I need to bleed brakes. Is there a way to pull black part of it without touching break lines?
    Jan 2010
    1999 Astral Silver
    An update on my ASI rebuild - they askeed me to send it back and with Mile High VX's heolp i got it out and sent it back. They took a whole week to thoroughly testes and fond a malfuntione they overlooked first time. Right now its working as exepected! So ASI stad by tey warrantly which is good to know. I did have to pay shipping (bummer) but not repairs.
    Jan 2010
    2001 black 1145
    help needed
    Just got my abs module back for second time from rebuilder, no luck still not working.
    It looks like I need to get another unit.
    I have a bosch but i hear that vehicross also has kelsey hays units. I could use a part number if anybody has it. I could also use a place to find another unit bosch or kelsey hayes if anyone knows a place.
    Jan 2010
    2001 black 1145
    abs fixed
    Got a used abs module (came with pump) for a 1998 Trooper, put it inot, everything works fine
    Nov 2003
    '99 Ironman 1405
    Quote Originally Posted by Daly View Post
    Good to know. Thanks for the info. Where and how did you find it? What did it cost you?
  1. isuzu axiom intake module question
    By djvx in forum Chit-Chat ...
    Last Post: 12/24/2010, 05:46 PM
  2. ABS Module
    By haggisgood in forum VX Troubleshooting...
    Last Post: 02/19/2009, 01:25 PM
  3. ABS module, how much??!
    Last Post: 10/02/2008, 07:42 AM
  4. ABS module
    By WiSDoM in forum VX Troubleshooting...
    Last Post: 09/01/2007, 02:26 PM
  5. TOD Module
    By WiSDoM in forum VX Talk...
    Last Post: 06/30/2006, 09:26 AM
