Results 1 to 15 of 22
Thread: to the electrical guys..
    so I have a mod in mind.. but not sure how to pull it off, was hoping someone here would be able to help
    nobody can ever find my door handles at night.. so what I want to do is install LEDs inside the door handles so they are lit up.. thats the easy part and its already done.. the hard part is im not sure how to wire them so that when i take the vx out of acc mode (ie turn the car off) the lights turn on for 30-60 seconds and then turn back off
    i have a fuse box thats controlled by the ignition so it would be easy enough to set up a relay where power to it opens the circuit and taking the power from it (pulling the key) will close the circuit.. but i dont know how to control the length of time... i can make my own circuit boards and such.. just not sure what i would need to do to make it work..
    any ideas?
    May 2008
    ok so you basically want the LEDs to turn on for 30 seconds after you've turned the car off correct?
    That shouldn't be too difficult.
    You can use the always fun, easy to find and incredibly cheap 555 timer and then wire it up in "Monostable" mode
    for more information you can look here: http://www.kpsec.freeuk.com/555timer.htm
    you can use the ACC line as your trigger and then the output can go straight to your LEDs...
    Depending on how robust the specific 555 chip is the voltage supplied by your cars battery might be too much for it, in which case you might want to consider some small bit of additional circuitry such as a transformer or power regulator to absorb any spikes and dips the electrical system might experience.
    You can get a 555 timer and probably everything else you need at your local radio shack for a couple bucks... (you can get it for pennies online).
    Feel free to shoot me a PM if you have any other questions, I do electronics stuff all the time. the 555 is a great beginners tool for electronics, nearly every class on electronics will have you using a 555 and an LED in various configurations, even that link I posted above is from a highschool electronics club
    Jun 2007
    2001, Proton
    a question if you dont mind
    If you have the lights go off after 30 seconds how do your passenfers find the handles when you all come back to the car from dinner etc? I mean when they get out they do not need the handles they need it when they are coming back so I do not see what the lights accomplish unless you wire them to your remote and they turn on when you unlock the car doors.
    Lightbulb
    Get a couple VX/Trooper domelights from a salvage yard & use the guts out of those to stay on, then stage down...the only drawback would be creating a dummy load or leaving the bulb in, so it would work properly.
    i meant the interior door handles.. exterior is no problem because i know where it is and i always open it for my ladies anyway
    dub.. thats an idea i could probably come up with a way to use a stock circuit board from the dome lights.. only downside to them is i know for a fact that those dimmers are really rough on LEDs.. but i could look around for other cars that have similar timers without dimming.. then tie it in.. hmmmm
    Aug 2006
    99, Silver, 1773
    I'm not sure what size of capacitor you would need, but if these LED's are drawing low enough current, you could just put a capacitor in parallel with your LED/Resistor. When the 12VDC goes away, the capacitor would continue to feed the LED till it ran out of juice (It would even give you the slow fade effect). Just an idea.
    I also you could check out this idea: Just look under "Power off time delay".
    http://ourworld.compuserve.com/homep...wden/page2.htm
    May 2008
    for a fade effect you'd need to use a capacitor and transistor. that's pretty easy to do as well.
    it's a more simplified version of this circuit
    Quote Originally Posted by Techy-D View Post
    That wouldn't be bad if his desire was for the LEDs to be on 100% of the time while the VX is running and then just stay on for X amount of time after he shuts it off.
    If the intent is for the LEDs to turn on when the VX is shut off and remain on for a minute then the 555 is the more appropriate option.
    As for Dome lights.... most of the time the timer is built into a special relay that controls all of the interior lights, not just the dome light.
    Jan 2006
    The cap is what I was going to suggest, It would be the easiest and prolly the cheapest route to take...
  1. Zero electrical power?
    By blacksambo in forum VX Troubleshooting...
    Last Post: 04/22/2014, 01:14 PM
  2. Electrical Problems
    By dmanske@cavtel.net in forum VX Talk...
    Last Post: 01/04/2012, 07:02 AM
  3. So what it be guys? lomg time sence i've talked to u guys...
    By CoastieCosta567 in forum Chit-Chat ...
    Last Post: 02/20/2010, 12:23 AM
  4. Dead VX, Seems Electrical
    By jbregar in forum VX Troubleshooting...
    Last Post: 09/20/2004, 10:04 AM
  5. Electrical Problems...
    By Jolly Roger VX'er in forum VX Talk...
    Last Post: 08/18/2003, 01:32 PM
