Results 1 to 15 of 26
Thread: stalling when starting
    Jan 2008
    Formerly 2000 Kaiser #0486
    I've been having the same issue of it sputtering and threw a p0171 code i believe and then today it actually died after turning on. Wouldn't stay running without some throttle applied. I took the idle control out and tried turning the key to on to see what happened and it popped the whole plunger thing out, is that normal? The plunger screws back in and i can't pull it out so i'm wondering if thats normal for it to pop out like that? If it's not this then would it be the fuel pressure regulator? This is my first 'new' car with sensors and such so i'm still learning. It seems like the symptoms my buddies Cherokee had and it was the Throttle positioning sensor on that.
    nznsi
    Quote Originally Posted by Knivx View Post
    It is possible that it is the TPS. There is a cleaning solution for that that seems to work for many, so it's worth a try.
    This is pretty insane really. Recently, there has been a 171 and 174 epidemic.
  1. Stalling. At wits end!
    By dallas121469 in forum VX Troubleshooting...
    Last Post: 05/07/2017, 05:49 PM
  2. stalling problem...............
    By H3_VX in forum VX Troubleshooting...
    Last Post: 06/19/2013, 04:03 PM
  3. help stalling
    Last Post: 11/07/2007, 02:40 PM
  4. smell and stalling
    By 99VX4x4 in forum VX Talk...
    Last Post: 10/06/2005, 07:44 PM
  5. stalling problem
    By Joe C in forum VX Troubleshooting...
    Last Post: 01/29/2003, 02:27 PM
