my area certainly qualifies. The middle of the desert but it is funny while it still hits 100 degrees most days we are not in the 110s and 120s anymore and it is worse now. What does make sense is if the fual cap is not allowing air in then the fuel pump needs to work harder but since the problem usually occurs after sitting you figure air would have gotten in overnite and it would not be as bad after sitting.
