Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: stalling when starting
    Mar 2012
    sold
    mine was doing this with a new irc (and maf sensor, tps, fpr, fuel filter) - i cleaned the throttle body and put some heat fuel additive in the gas tank (basically rubbing alcohol) and it seems to have fixed it
    i think its just too damn cold!!!!!
    EXACT same symptons - only dying when put in reverse and starting to move
    never threw any codes
    Oct 2009
    2001 Mica Green VCS 0403
    Check your air filter and the connector that is attached to the air filter cover. My wife had the problem with her VX dying after I had installed new headlight bulbs. She called me from work with her story and I told her to stop at a automotive store and have one of the young bucks put some fuel cleaner in her tank (ha ha). It did ok for her running around at lunch but then acted up again on her way home. After thinking about what the problem could be I realized I had left the connector off. Just some food for thought.
    Mar 2012
    sold
    Quote Originally Posted by soggybottomboyz View Post
    i did this with my mass air flow sensor plug before - but that wasnt the case this time - checked every vacuum hose and plug i could see and everything looked good - plus, if it was a plug disconnected you should almost certainly throw a code
    Astral Silver - 1131
    had this problem... I checked the MAF, secured the ring, and warmed her up on days below 5Deg F. , Was low on oil too. I surmised it was frozen vapor through the system or something.
    Did not happen again.
  1. Stalling. At wits end!
    By dallas121469 in forum VX Troubleshooting...
    Last Post: 05/07/2017, 06:49 PM
  2. stalling problem...............
    By H3_VX in forum VX Troubleshooting...
    Last Post: 06/19/2013, 05:03 PM
  3. help stalling
    Last Post: 11/07/2007, 03:40 PM
  4. smell and stalling
    By 99VX4x4 in forum VX Talk...
    Last Post: 10/06/2005, 08:44 PM
  5. stalling problem
    By Joe C in forum VX Troubleshooting...
    Last Post: 01/29/2003, 03:27 PM
