Results 1 to 5 of 5
Thread: noise bleed over into passenger speakers
    Jul 2008
    vx-less rocking an acura rsx type-sssssssss
    currently i am having some noise coming through on the passenger door speakers.
    my setup:
    kenwood excelon x492
    polk momo MMC6500 components in the doors
    rockford fosgate p450.4 amp
    i have swapped the rca's at the amp to see if it was the rca's themselves, but it remained on the passenger side. i currently have the crossovers mounted on the kickpanels just forward of the doors. the tweeters are mounted on the sail panel on the doors. the noise comes on only when the engine is running.
    anyone have an idea if the components behind the passenger kick panel could be emitting some emi? or any other ideas at all?
    thanks
    Steven
    double check your grounds....thats usually a common noise problem...
    and of course make sure your RCA's are as far away from your power cable as possible...
    make sure your crossover is wired properly (ie + to + )
    where is your power wire to the amp run? if you are running your speaker wire too close to your power wire you could get some noise directly into the speaker wire from your power
    as pb said.. make sure your RCA wires are clear of any type of power wire and when they do have to cross paths, try to do it at a 90 degree angle to cut down on noise
    Jul 2008
    my rca's are ran on the driver side and my power wire is on the passenger side
    for my amp ground, i am using one of the bolts that secure tie downs to the frame in the back
    the polarity is correct on all of the wiring as well...
    the only thing i can think of is that the power wire is ran along side of the speaker wiring for the passenger door...
    Quote Originally Posted by lunaticharness View Post
    try re-routing the speaker wire to the passenger door.. take it down the middle of the passenger seat and across the floor board, then straight across under the carpet to the door... i had to do that with my RCA wires.. out from the head unit into the passenger foot well.. down the center of the seat and out to the amp
  1. New speakers help please
    By BlackVX in forum VX Modifications...
    Last Post: 09/20/2010, 05:06 AM
  2. Speakers...again
    By Chopper in forum VX Modifications...
    Last Post: 03/23/2008, 01:13 PM
  3. Can I rebuild/bleed/fix my cheap floor jack?
    By MustangO4 in forum General Tips...
    Last Post: 11/11/2007, 12:47 PM
  4. new speakers
    Last Post: 04/13/2006, 10:29 AM
  5. Stock Speakers
    By Sheik-YurBooty in forum VX Talk...
    Last Post: 10/03/2003, 08:33 AM
