Results 1 to 4 of 4
Thread: how to flip backseats all the way over???
ChicagoKelly how to flip backseats all the... 09/15/2008, 01:51 PM
MSHardeman ChicagoKelly, There is a... 09/15/2008, 02:04 PM
nocturnalVX Come out to our next meet... 09/15/2008, 10:26 PM
BlackVXer99 you will need to scoot your 2... 09/20/2008, 09:28 PM
    1999 Silver Vehicross 1864
    Sorry for a really dumb question here but I searched this forum several times and couldn't find it (mebbe its TOO dumb?!)
    I have a 99 VX. From passenger side door, I can lean in and flip the back seat lever toward me - this allows me to fold the backseat DOWN FLAT.
    But how do you then get the backseats to FLIP OVER so they are squished up next to the Front Seats? I didn't even know this was possible til I read it here - and I've had this car for years now. Having more space back there would be AWESOME! Thanx!!
    2000, Ebony, VX, 0370
    Thanked: 12
    ChicagoKelly,
    There is a latch at the base of the back of the back seats that you will need to release to get them to flip forward. The easiest way to see/do this is to open the rear door so you can easily access everything. If you look at where the back of the seats meet the bottom of the seats you will see where the seat belts mount to the floor and pass through a hole between the backs of the seats. To get the seat flipped forward you will need to pull the seat belts through this hole first so that they are laying on the floor. Just to the right (passenger side) of where the seat belts mount to the floor you sill see a latch holding the rear seat down. Pull that level up (mine has a little strap attached to it) and then lift the seats up and flip them forward.
    I have a 2000, but I think that it's the same on the 99's; there is a strap with a metal hook attached to the back of the passenger side rear seat. Once you flip the back seat forward the metal hook latches on to a metal "ring" on the floor right behing the center console (it's hidden by a flap of carpet). That will help secure the rear seats in place when they are flipped up.
    Hope that helps.
    Wink Come out to our next meet...
    and we will answer that and any other questions you might have. Hope to see you soon!
    My VehiCROSS
    Dec 2007
    1999, Ebony, VX, 5185
    you will need to scoot your 2 front seats up a bit, took me a while to learn that when i first got mine
  1. Ball Joint Flip - Did you do it? Why? Why Not?
    By taylorRichie in forum VX Modifications...
    Last Post: 02/05/2016, 08:07 PM
  2. Military Tires? Need Help Before I Flip the Switch
    By Ala5ka in forum Wheels and Tires
    Last Post: 09/16/2011, 06:25 PM
  3. Ball Joint Flip Problem
    By TEN36VX in forum VX Troubleshooting...
    Last Post: 06/09/2008, 07:35 AM
  4. HELP Ball joint flip problems VX on blocks!!!!!
    By LittleBeast in forum VX Troubleshooting...
    Last Post: 04/10/2008, 10:45 PM
  5. Purpose for ball-joint flip?
    By coachreed in forum VX Modifications...
    Last Post: 09/15/2003, 04:37 AM
