Results 1 to 15 of 43
Thread: Help with hard drive
    I can't remember the exact error message - something about unable to recognize USB device.
    I'm not getting noises from it that would make you pucker (like the read head dragging on the disk). I do get a clicking sound like it's trying to read & maybe not finding the zero sector. It was hooked to the kid's computer that crashed a while back & hasn't worked since. Since it was the kid's computer, it prolly didn't get the virus updates as regularly as it should've. Maybe it got attacked???
    "One thing you can try is to remove the HD out of its USB enclosure and hook it up to your computer as an IDE or a Sata drive."
    I was going to try that but wasn't ready to try that yet since the new 'puter is running Vista & I'm still learning it's idiocyncrocies. I really don't care about saving the drive - I just wanna save the data.
    "It's been a while, but I had luck with ..."
    Thanks Kenny - I'll have a look.
    Apr 2007
    2001, Proton #1238
    Vista shouldn’t be a problem, Disk Management is pretty much the same as the one in XP. USB has a bad habit of rejecting HDs with problems that would normally be corrected by error checking if it was hooked up directly to the computer.
    If you’re not hearing a constant “ZIP CLICK, ZIP CLICK, ZIP CLICK” or if you’re not feeling the gyro forces when it power up then chances are it’s just data corruption that needs error checking.
    Yeah, if you can plug the drive in, go into Disk Management and look and see if its in there. It may not have a drvie letter assigned to it, which you may have to do manually. If you can get a drive letter assigned to it, you can drop out to a command prompt and run chkdsk on it. That should fix any lost clusters or cross-linked files.
  1. Hard to believe these are models
    Last Post: 02/08/2010, 08:58 AM
  2. Saying goodbye is so hard
    Last Post: 04/22/2009, 08:49 PM
  3. did i push my VX too hard?
    Last Post: 03/31/2009, 01:54 PM
  4. Hard to believe...
    Last Post: 10/24/2007, 07:10 PM
  5. Hard Shifting on the 2-3
    By Joe C in forum VX Talk...
    Last Post: 08/13/2003, 02:34 PM
