Just wondering, I have tried several things but nothing works for the screws that hold on the cladding, not sure if they are called torque screws. Anyone know what and what size?????
I had a regular shaped allen wrench that did the job just fine!
Be careful though , as you can strip them. Tighten them up as tight as possible with out it just spinning around with no tension.
Use a regular style allen wrench that fits, take it slow and you'll be fine![]()
Live Free or DIE!
I have tried allen wrench etc, just need to know the size to get, the ones I have don't fit, would prefer the torque wrench but just not sure what size.
They "ARE" called torx screws and you can get torx sockets for a socket wrench that will work fine. There are more torx screws on the VX than just the cladding, so a set might be a good thing to have if you are the do-it-your-selfer.
Alright, thanks, I knew what they are but have a few of the wrong size, I will just get a set.
Torx wrenches![]()
NAVIGATOR
I highly recommend a good bit set with a flexible driver and a magnetic bit extention to go with it. That one tool is so versatile, I use it more than any other.
Here's one from Sears for $10. Hard to beat that package. It's not Craftsman, so no lifetime warranty.
Sears item# 00930544000
My set came with a driver more like this one, though: (item 00930561000)
For interior screws and such, a tight angle bit ratchet like this one makes that kit even more useful (item 00941716000)
-Daver
-Daver
;Dp; Thanks Daver, That looks like exactly what I need. I can relate to pictures!!
