Results 1 to 15 of 29
Thread: Fuel Pressure Regulator
    I might still have the packaging from mine too. I will poke around in the garage and see.
    And you know, I changed my FPR before Moab this past May, and on occassion, my VX will have a surging idle when I start up. It does it for 5 or 6 revs and then levels out normally. Its weird.
    Oct 2006
    2000, Green, Vehicross, 0054
    Littlebeast, responded to your PM, I forwarded the part and the instructions to someone else on this forum shortly after I posted, I didn't keep the message but whomever has the allen wrench and instructions, please let littlebeast know if you're done with the FPR change
    Jun 2007
    2001, Proton
    PM Sent I have the tool and instructions
    I am waiting to hear back
    2001, Ebony Black, 1153
    Thanks everybody circmand is sending it on to me
    I barely got the VX home yesterday, but hopefully it will be back up and running in no time
    Dec 2002
    2001 Ebony 0177
    0177 has done this, very mildly (50 or 100 rpm) very occasionally, since the day it was born. A light stab on the loud pedal ends it pronto.
    ya, i have the same issue......
    usually like 2k rpm idle with your foot for like 3 seconds will fix it for me...
    Mar 2006
    2001 FOXFIRE 0579
    get me a part number also, i have an "in" at a gm dealership, more importantly the parts department, and can usually get a bit of a price break. when i see the part number, i will call and get a price to compare around. i need to do this also.
    By "barely got it home yesterday" I mean it died on me every single time I started it without my foot on the accelerator, and it died every time I started to slow down or brake and did not have my foot on the accelerator keeping it above 1k rpms, and when I gave it gas it would choke and sputtering and barely get up to speed at all. I know what you guys are talking about mine does the bouncing idle every once and a while, but yesterday was scary in 5pm traffic in Houston, knowing that the VX would cut off if I hit the brake without my right foot on the gas at least above 1k or so. I will get the part numbers and photos up as soon as I get the part in.
    Jun 2007
    2001, Proton
    what were you doing
    using the brakes at 5 in Houston anyhow?;eekp;
    ex 1999 ebony black vx 1979
    Mine was doing that exact same thing Little Beast. I fixed it with a new idle control valve. It gets filled up with carbon like the EGR does. You can clean it but it was a fairly inexpensive part ($50 or so)and its a 5 minute replacement so I just put in a new one.
    Jody
    Quote Originally Posted by Chopper View Post
    Funny you say this because this has been my "quick fix" for this until I replace some guts. Unfortunately, it did not work for me this weekend. On start, the engine instantly revved and idled at 2500. AFter about 3-5 seconds, it would drop to about 1500 and rev right back up to 2500 again. Rinse and repeat a few times. Typical rev on startup, but it has never revved so high. I pumped the accel once up to about 3k, which usually kicks it in to acting normal, but strangely enough, it stayed at 3k. I hopped out real fast and look under the hood to see if the throttle cable was sticking, but the throttle body and cable were fine. I gave the TB a rev by hand and it still continued at 3k. Hated to do it, but I let it stay there for a few more revs before it finally gave in and stalled. I didn't want to hot cut the ignition. I turned it back on about 10 minutes later and it was fine. Turned right over too.
    Needless to say, she stayed in the garage all weekend. I don't need to wear this problem thicker than it already is. I have enough parts on my "to do" list already.
    I did the FPR swap and Idle Control Valve cleaning last night, and the VX now idles and drives A LOT more smooth! Probably as smooth as I have ever experienced. Pics will follow tomorrow probably. I hate to admit this but everything went smoothly except that at first I was turning the back bolt the wrong way because it was facing the firewall and I didn't stop to think about which way to turn it, but I got it off after I realized I was trying to tighten it at first and then I just replaced both of those allen head bolts with some 12mm spares bolts from other VX projects and it looks good as new, and more importantly runs better than ever, literally!
    Oh and the Idle Control Valve was pretty black in there, but it is spotless now
    Jun 2007
    2001, Proton
    still waiting
    on post and pics about the fix
    Dang! I am so sorry! The only photos I have right now are there:
    Which probably don't help too much, but those are the part numbers and GM reference numbers that LDub wanted and a pic of the part. What other pictures did you want?
    2000, Ebony, VX, 0370
    Thanked: 12
    circmand,
    I'm not sure which pics you're waiting on, but the link that LittleBeast listed above of Dino's fuel pressure regulator replacement how-to is excellent. I used Dino's step by step when I replaced my regulator and everything went off without a hitch.
  1. fuel pressure regulator, missing hose
    By SEBACOQUI in forum VX Troubleshooting...
    Last Post: 04/08/2013, 02:04 PM
  2. Fuel Pressure Regulator Replacement
    By Dino in forum General Tips...
    Last Post: 09/25/2007, 10:24 AM
  3. Fuel Pressure Regulator
    Last Post: 09/20/2007, 07:20 PM
  4. fuel pressure regulator?
    Last Post: 04/07/2006, 07:15 AM
  5. fuel regulator SC/5psi?
    Last Post: 06/20/2004, 10:06 PM
