Results 1 to 11 of 11
Thread: ABS light on All TOD lights off?
    Sep 2007
    I got in my VX today " my GF has been driving it all week" and the abs light was on and all the lights for the TOD were off. she has no clue and now neither do i.
    I have an OTC Genesis and it will not get in to the system. Soooooo now what?
    I tried to pull codes the old way as described here but i could not get any reaction from the abs or tod system.
    Help?
    the computer under the passenger seat controls your TOD.. iirc it also affects your abs... so i would check that first.. maybe a blown ABS fuse.. that would turn on the abs light.. not sure about the tod lights but if they are controlled by the same computer it could affect those lights too
    Sep 2007
    Both the 20 amp and the 40 amp fuses for abs are good, so??
    1999,White,Iron Man,1429
    Unless you have a tech 2 scanner you will have to pull the codes by jumping the pins on the obd II connector. If you follow the procedure in the manual you have to inverse the pin numbers. In other words looking down on the plug instead of up. At least that is what I had to do to pull the codes. All the codes and trouble shooting instructions are in the manual.
    Todd
    Mar 2005
    01 Ebony - #0379
    Quote Originally Posted by Rene M View Post
    Check all the fuses in the side panel.
    Is there a gauge cluster fuse?
    This sounds very familiar with the ABS light on and the TOD lights off....
    Sep 2007
    I have tried to pull codes with no luck at all. As for the fuse block there all good.
    Dec 2004
    Forget the codes - you probably blew the ToD system fuse under the hood. Behind the battery (meaning, toward the firewall from the battery) is a fuse box. Check the fuses there.
    I had the EXACT same symptoms earlier this year when a wiring harness under the car broke and the ToD system wires were resting on the catalytic converter - the insulation melted and the wires shorted, blowing the fuse. I had no ToD lights at all and a steady ABS warning light on.
    Do yourself a favor next time, Rene - try to search before posting. If you had, you would have found this out the same day, not a week later.
    I don't mean to pick on you for not searching (that's Ldub's gig!) but we all need a periodic reminder that most of the problems any of us will see have been experienced and posted by someone else already.
    Jun 2003
    I would start looking at the tod module, since you're not getting a check tod lite. Download the electrical manual and start checking voltage and continuity of wires.
    Check your ground wires, there have been numerous problems caused by them.
    Have you physically checked the tod module under the pass. seat? Maybe she stuck something under the seat and knocked a connector off?
    Do you know whether the tod and/ or abs are actually working? Maybe the tod indicators are just burned out or disconnected???
    There is some relation between tod and the abs sensors, so you may be tracing wires.
    Good luck and report back whether or not you find a solution.
    Feb 2015
    1999 white
    1999 vehicross
    hi ,checked tod computer connectors, fuses in interior and engine bay, no blown fuses, wiring underneath intact, but no tod display or mechanical operation of four wheel drive, abs light on. I need to know where to go from here , thanks
  1. little lights in the bumper/fog lights
    By GAMEON in forum VX Troubleshooting...
    Last Post: 04/15/2014, 03:42 PM
  2. spoiler tail light / hazard light question !
    By Spike in forum VX Talk...
    Last Post: 05/21/2007, 09:27 PM
  3. Tone's Light Adapter for Trailer Lights
    By ojmagg in forum VX Troubleshooting...
    Last Post: 11/20/2006, 11:03 AM
  4. Bad Fog Lights/Running Lights
    By Bimati in forum VX Talk...
    Last Post: 10/12/2006, 08:00 PM
  5. Dead short in Rear Light/Instrument light
    By Damien Jones in forum VX Troubleshooting...
    Last Post: 07/16/2006, 08:49 PM
