Results 1 to 3 of 3
Thread: Rear Door Check Arm Replacement
    Feb 2003
    2001,Black
    Hello all....
    The check arm on my rear door recently broke...just sorta snapped with a loud ugly sound when I opend it up the other day. Half of it is attached to the door, the other half is in the frame of the car...
    I have located a replacement part, but was wondering if anyone has ever replaced this particular component, and if there was any advice on "how to" or at least "how NOT to" do so...
    Looks like a lot of the trim at the interior opening of the rear door will have to be removed to access the connection point on the frame...anyone have the proper steps of removing these trim peices? I can just see me getting it off and ending up with "extra" peices when I try to re-install them....
    As always, any advice would be a big help, and greatly appreciated!
    1999,White,Iron Man,1429
    I have one on order. Mine folded up so I was forced to remove the assembly. Not much to it really. You just have to pull the panel back to access it after you remove the screws.
    Todd
    Feb 2003
    2001,Black
    Thanks Todd....I appreciate your input....
  1. New rear door
    Last Post: 08/06/2012, 05:47 AM
  2. Door Lock Rod Clip - help finding replacement
    By davidrepas in forum VX Troubleshooting...
    Last Post: 01/01/2012, 05:59 PM
  3. Rear door check stop
    By FlyingV77 in forum VX Troubleshooting...
    Last Post: 11/22/2010, 05:06 PM
  4. Door check arm pin
    By moon buggy in forum VX Troubleshooting...
    Last Post: 08/06/2005, 04:02 PM
  5. Check Engine Light - After PCV Replacement
    By Child's Play in forum VX Talk...
    Last Post: 05/23/2004, 09:07 PM
