Results 1 to 8 of 8
Thread: How long are SS brake lines?
twistedsymphony How long are SS brake lines? 08/20/2008, 08:14 PM
Ldub I can't tell you what the... 08/21/2008, 06:01 AM
MSHardeman Dub is, of course, correct. ... 08/21/2008, 07:54 AM
twistedsymphony AHHH ok... I completely... 08/21/2008, 08:09 AM
MSHardeman Just a word to the wise (or... 08/21/2008, 01:43 PM
    May 2008
    I need to replace the front rotors calipers and pads so I figured I should do the brake lines as well.
    I ordered a set of stainless lines but they look REALLY SHORT to me.
    Also there are 5 of them, one looks like it's a central line of some sort.
    did I get the wrong parts or am I just paranoid?
    Arrow
    I can't tell you what the length should be, but the fifth line is the center line that goes between the frame & the junction on the rear axle to supply the rear calipers.
    2000, Ebony, VX, 0370
    Thanked: 12
    Dub is, of course, correct. The fifth line goes to the junction at the rear pumpkin to supply the rear calipers. The shorter two of the four remaining lines should be for the rear calipers (since there is no travel to deal with) and the longer two of the four should be for the front. The front lines should also have an aluminum "ring" in the middle of them because there is a place for that to mount at the wheel spindle to keep the line out of the wheel/tire.
    Quick piece of advice: if you are replacing the lines please be sure to plug up the hard lines when you take the old flex lines off. When I replaced my lines with stainless I let the brake system run dry, and have had a bear of a time getting it properly bled. If it does run dry, the engine has to be running while you do the bleed. I did all of this and I still think that I have some air in the lines because my brake pedel will hit the floor if I press on it hard enough.
    May 2008
    AHHH ok... I completely forgot that with a solid rear Axel the rear lines wouldn't have to be very long... now it makes complete sense.
    I have a friend who specializes in brakes that's going to help me out with the install. I'm planning on draining the whole system and replacing it with synthetic brake fluid and he's got a power bleeder (hooks up to an air compressor for draining/refilling/bleeding)
    thanks everyone
    Thanked: 12
    Just a word to the wise (or in my case not so wise). After trying to bleed the brakes for a day and a half by myself I finally took it to a mechanic and he found out, from Isuzu, that the engine must be running during the bleed. From what he tells me, the ABS module runs dry, and with out the engine running it doesn't push fluid into the module so you will never get all of the air out (my case). With the engine running, it some how takes the ABS module into account and forces fluid through it, thus getting all of the air out.
    May 2008
    That's somewhat of a scary prospect... the ABS shouldn't have that much control over your brakes...
  1. Which Brake Lines should I order?
    By H3_VX in forum VX Modifications...
    Last Post: 03/13/2015, 06:48 PM
  2. brake lines
    Last Post: 06/21/2013, 06:26 PM
  3. Help with replacing Brake Lines
    By frankd14321 in forum VX Troubleshooting...
    Last Post: 12/10/2012, 07:41 AM
  4. EBC brake pads and Apex brake lines
    Last Post: 12/14/2011, 01:15 PM
  5. Steel braided brake lines?
    By Dallas4u in forum VX Modifications...
    Last Post: 10/17/2005, 11:22 AM
