NICE
A little more offset & it'd be perfect.
NICE
Nyuk Nyuk Nyuk![]()
There is no need to re-index unless you have maxed out your adjustment. Re-indexing accomplishes nothing except to gain more room for the adjustment arm to swing (the short arm that connects the adjustment bolt to the rear end of the torsion bar).
If you need to re-index here is a procedure I wrote up a few years back:
Isuzu Torsion Bar Re-indexing
If you have run out of adjustability when trying to crank your torsion bars to raise the ride height, it may be time to re-index the torsion bars. This operation simply regains room for the torsion bar adjustment arm to swing while cranking the adjustment bolt.
1. Jack up one side of your vehicle until the front wheel is off the ground, and place a jackstand under the frame. Don’t support the vehicle by any part of the front suspension, your goal is to unload the suspension as much as possible. Refer to your owner’s manual for safe jacking procedures. I recommend safety glasses as well, mostly to protect your eyes from the grit that will inevitably fall off the vehicle while you are working under it.
2. Using a half-inch socket wrench or breaker bar and a 27-mm socket, get under side of the vehicle, midway between the tires. Locate the torsion bar adjustment bolt (these are my terms, not necessarily the same terms Isuzu uses). It is easy to see, just inside the frame rail, on a crossmember roughly in line with the B pillar (the B pillar is between the two side doors).
3. Remove the bolt, counting the number of turns until tension is entirely relieved on the bolt. The newer the vehicle, the easier this bolt will be to turn. Due to inevitable corrosion, older vehicles may require the use of a long breaker bar and/or penetrating oil. After the tension is off, continue removing the bolt until it comes out, along with two large half-moon shaped nuts.
4. (Note: this step might not be necessary on all vehicles. If the torsion bar doesn't have any tension holding it down to the crossmember, you can probably skip Step #4) Get a 17-mm socket and loosen (but do not remove) the nuts on the lower control arm bracket at the other (front) end of the torsion bar. This will allow the bar to pivot slightly and take the remaining lateral tension off the bar. Without doing this, the tension will make it difficult to lift the rearward end of the bar from the crossmember. The bracket nuts are very tight, so a breaker bar is helpful to break them loose.
4A. Alternative to #4: use a jack to force the torsion bar up off of the crossmember. I don't recommend this idea, working in close proximity to large springs under tension makes me nervous.
5. Make a mental note of the angle of the adjustment arm on the torsion bar. Lift the rearward end of the torsion bar enough to pull the adjustment arm off of the splined end of the torsion bar. The arm isn’t held on to the bar by anything but friction at this point.
6. Rotate the adjustment arm so the end away from the torsion bar is higher than before, and re-insert it onto the torsion bar. It should only be necessary to rotate the arm one or two splines on the torsion bar. Also, it's not a bad idea to re-grease the splines before re-installing the adjustment arm.
7. Line up the adjustment arm so it will fit into the U-shape channel of the crossmember, and set the torsion bar/adjustment arm assembly down on the crossmember.
8. Tighten the nuts on the front torsion bar bracket on the lower control arm.
9. Grease the curved surfaces of the half-moon adjustment arm nuts. Reinstall the adjustment arm bolt and half-moon nuts. Once you feel some tension on the bolt, start counting the turns. Crank about the same number as it took to get the bolt off, this should get you in the ballpark of the ride height you started with. If your goal was to take the ride height higher than before, you should be able to do so now. Either way, some fine adjustment will almost certainly be necessary to even out the height side to side and front/rear.
10. Repeat Steps 1 through 10 for the other side.
11. Go for a drive around the block to settle-in the torsion bars and adjustments.
12. Check your ride height again, front to rear and side to side. I just do this by eye, because you can drive yourself nuts trying to measure the height precisely. Exact ride height will vary due to a variety of factors, including vehicle load (even how much gas is in your tank), slope of the ground you are measuring on, basic slop in the suspension, temperature of the shocks, etc.
No, there is no "lower limit" to the adjustment...if you lefty-loosey the adjustment bolt (as to lower the ride height) enough the bolt will just come on out entirely.
It isn't uncommon for a longish breaker bar to be needed for adjusting the ride height bolts unless they have been turned recently.
Sweet , thanks...that is what i was looking for.
No problem, you also mentioned an interest in lifting, aside from the expense. Just so you know (in case you don't already), a lift can be achieved for less than $200. Most of us use the Old Man Emu coil springs in the rear and a few turns on the torsion bar bolts to gain 2.5". The coil springs are the only parts you need to buy! Check out the "lift wiki" thread for more info and optional parts...
