Has anyone else had problems with the driver side controls for the passenger side window? The passenger side controls work fine, indicating that there is no issue with the motor assembly...but the driver side contols fail intermittenly...sometimes they work...sometimes they don't...when they don't I can use the passanger side switch to raise/lower, but it's a pain. I'm thinking it's a loose wire or the switch...multi-meter time I guess....
stewpid, stewpid, stewpid...
