Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: tranny trouble
  1. #16
    Feb 2004
    '01 Ebony #0830
    Help with adjustment of Trans Mode Selector
    Here is a VERY rough drawing of the mode selector. The arrows show the slotted holes where the bolts go. There is approximately 5-10 degrees of rotation available here. Does this affect shift timing? Or anything at all?
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
  2. #17
    I've got a mode switch laying around somewhere and I'll try digging out my paper set of manuals this weekend, to see if there's any mention of adjustment proceedure.
  3. #18
    Feb 2004
    '01 Ebony #0830
    Thank you!
    Thank you for your help!
  4. #19
    procedure 1
    a. Place selector lever in neutral
    b. Remove selector lever from the mode switch
    c. Remove the mode switch cover
    d. Loosen the two 10mm screws
    e. Rotate the mode switch until the slot in the mode switch
    housing aligns with the selector shaft bushing, and
    insert a 3/32 inch (2.4mm) drill bit or punch (1) into
    The slot
    f. Tighten the screws to 13Nm (113 in/lb.)
    g. After completing adjustment, snap the mode switch cover
    into place
    h. Reinstall the selector lever
    procedure 2
    b. Disconnect transmissiom harness connector from mode switch connector
    c. Remove mode switch connector with bracket from the
    transmission case
    d. Connect multimeter (resistance mode) to terminals 1(E)
    and 4(H) on mode switch connector
    e. Loosen two mounting screws
    f. Rotate mode switch in both directions to determine the
    range (approx. 5 degrees) of electrical contact
    g. Position mode switch in middle of contact range
    h. Tighten two mounting screws
    i. Remove multimeter and install mode switch harness connector with bracket to the transmission case
    j. Connect transmission harness connector to mode switch connector
    the illustrations:
    You can find enlarged images in my gallery.
  5. #20
    Feb 2004
    '01 Ebony #0830
    Thanks Sarge! That is a great help! I knew there had to be something adjustable with the unit. I'm going to print out your instructions and do the adjustment this weekend. Many thanks again!
    ---JIM---
  6. #21
    I updated my post above with the illustrations.
  1. Trouble again...
    By Exclamation in forum VX Talk...
    Last Post: 05/02/2011, 02:17 PM
  2. outline of tranny filter on tranny pan......
    Last Post: 05/16/2006, 07:44 PM
  3. VX trouble
    By dogue in forum VX Troubleshooting...
    Last Post: 02/16/2006, 02:21 PM
  4. Help... Switching from mechanical tranny to fluid tranny???
    By ScubaSteve in forum VX Troubleshooting...
    Last Post: 10/03/2003, 02:41 AM
  5. VX Trouble
    By jim falcione in forum VX Talk...
    Last Post: 12/26/2002, 05:43 PM
