Results 1 to 15 of 15
Thread: Wheel recommendation
    My OEM 18s on my VX are shedding chrome like crazy. I was hoping that my search would turn up a host of pics that other members have purchased to replace the OEMs but no such luck. I was hoping to find something with the same config as the OEMs but under $200/each. Your recommendations and suggestions are most appreciated.
    Scott
    2001, Dragon Green, 1342
    well, I run the MKW's, really happy with their workmanship. They dropped my model of course, but they still have a bunch more that would work.
    Oct 2006
    2000, Green, Vehicross, 0054
    I was under the impression you could imply have the wheels rechromed, I may be wrong but if not, that would be the easiest solution
    I'd rather not have more experience with chrome. Living in New England with salt use in the winter just breaks them down quick.
    well, you could run 2 sets, pretty ones in the summer and the OEM's in the winter with a good winter tire. I took one of my OEM,s had the peeling chrome sand blasted off and then powder coated with a chrome like finish so that I would have a full size spare.
    Not a bad idea. If I could find an operation that performed such functions I'd blast all the chrome off and powder coat them and I wouldn't need a second set.
    2001, Ebony Black, 1153
    Quote Originally Posted by ScottinMA View Post
    And chrome add a small bit of weight. The most simple and cheapest way to go would probably to have them High polished by a local chroming shop. I had it done to my RX8 wheels and they look like they are chromed except there is no chrome just high polished shine that I can make look even better with some TLC, here is a pic of the high polished wheels, cost me around $300 to have all 4 done here locally:
    VERY nice! I'll try to find such a shop here on Cape Cod. Thanks!
    Sep 2004
    1999, Astral Silver, VX, 0938
    Blast and Powder Coat your OEM's, Prices very $50-$100 each.
    Quote Originally Posted by VCrossfan View Post
    OK...Just can't find someone nearby that can do it for me. Clearly the opinion of the list.
    Thanks for the post.
    2000, Kaiser, 0134
    I went with black wheels... Less maintenance and I can sharpie and scars (thanks Larry )
    The beat goes on...
    Found a chroming shop. The plan was to condition the wheel and powder coat. Cost $100/wheel + fees for tire removal, replacement and balancing. Even the guy at the shop thought it would probably work out to be better just to buy new since Town Fair Tires will do all the labor for no charge. So back at it again, searching for a replacement wheel for my 18' OEMs. New ones will not have chrome. Wouldn't mind getting black.
    I love my AR Teflon Chambers. Talk about easy clean-up.
    Well, unless you do this to em:
  1. Shop Recommendation?
    By calilu in forum VX Talk...
    Last Post: 03/28/2007, 12:49 PM
  2. Need recommendation, best way to run amp power cord
    By darkl4805 in forum VX Modifications...
    Last Post: 11/30/2006, 07:49 PM
  3. Tire Recommendation
    By Anita in forum VX Talk...
    Last Post: 09/21/2006, 04:02 PM
  4. CD changer recommendation
    Last Post: 11/29/2004, 08:40 AM
  5. Tire Recommendation - Help!
    Last Post: 08/22/2004, 08:57 AM
