Lately my 'Check' TOD light has started flashing after about 10-15 minutes of driving. I assumed it was either heat related (connector getting cooked by exhaust) or wheel speed sensor related (my front tires are worn significantly more than my rear tires). I checked all connectors under the VX & found nothing. I aired down my rear tires with no improvement. Never quite got around to checking for error codes.
Day before yesterday, I drove the VX to work (brother in law is driving my DD since he blew the head gasket in his jeep). On the way home I exercised my ABS ... panic stop ... darn near stood the VX on it's nose (did you know that in Virginia a shot nosed kid driving a slammed Prelude has right of way when pulling onto a primary road from a secondary road?
). Anyway, TOD light still flashing at that point but then I stopped to drop some stuff off for blujfan. When I got back on the road ... no more Check TOD light. It's been fine ever since.
So what logical conclusions can we make:
1) TOD & ABS are interconnected and can effect each other (they don't).
2) Something was loose and the panic stop adjusted things back to normal & I should expect the light to come back on soon.
3) My Proton kinda likes blujfan's Proton & was just showin off by fixin itself
4) This thread was started for the sole means of setting a new record for thread jacking (twice in the original post ... 3 times if you count this sentence).
Anyway, does anyone have any thoughts or comments on the TOD issue?![]()
