Results 1 to 15 of 17
Thread: How are you guys wiring your roof mounted lights. (I searched)
    2000, Kaiser, 0134
    Wondering how you guys route/wire your Roof Mounted Offroad lighting.
    I've got a couple I need to mount, but I'm not sure the best way to get the wires into the cab or Engine compartment.
    What have you guys done?
    Mine will be mounted directly onto my Thule Xpedition Rack.
    Apr 2007
    2001, Proton #1238
    I haven’t don it but I think they go up thru the back and use the existing wire hole for the upper brake light.
    i think bart did that.. i used a hobby box to hold relays in the engine bay and ran the wires up under the hood molding and up inside the passenger door opening weather stripping
    Arrow
    Same here, ran the switch wires through the grommet by the brake booster to the relays under the hood, then up the pass side weatherstripping to the lights.
    Not as clean to look at as Barts, but easier to remove if I decide to change things around.
    I used a 2" square piece of aluminum box tubing bolted to the floor of the rack from side to side, to raise the lights up enough to "see" over the front cross peice. That way, I didn't have to drill into anything that shows.
    2000, Kaiser, 0134
    Ha...
    Zeus your lights were the inspiration for me to mount my lights to my xpedition (smaller sleeker lighting) Hella FF100s.
    Thanks for the tips!, I'll probably keep the wires toward the front, no spoiler entry. Don't want to run wires clear to the back, then clear under the hood, and then back into the dash.
    Thanks again!
    2000, Kaiser, 0134
    Agreed! is yours the 695 or the 696?
    Mine's the smaller rack, might end up getting a bigger one down the road.
    I ran all my wires to the rear of the roof and through a hole I drilled in the spoiler.
    From there, everything goes along the headliner, down the pillar and behind the dash through the firewall hole.
    Since the photo above was taken, I have added a WeatherPack connector so I can remove the roof rack and cables with ease. I am almost done updating VX MADNESS, I will have detailed photos of my light setup included. Should have it all done by next week sometime.
    Moab video will be coming soon too!
    The WeatherPack connector I got makes removing my entire setup really easy now. I highly suggest getting one of these to unhook everything. They work really well. I used a six wire connector. Got it from Summit for like $10.
    Quote Originally Posted by taylorRichie View Post
    Mine is 3rd size - not a Thule branded Xpedition though.
    2000, Kaiser, 0134
    Looks good Bart...
    I'm going to order the connectors as you suggest. However I'm not entirely sure how I'll wire yet... I just may be going through the center off the roof
    I installed an electronic Sunroof in my S10, so I think a small hole will be ok in my VX... not entirely sure... yet.
    Thanks for the updates and images... Zeus yours looks like the "IDEAL" size... can it fit a spare? I'll just check it out tomorrow.
    Later!
    yea i used the weatherpack connectors too makes removal easier.. my vx looks naked without my roof rack/lights.. but with an improvement of 30-40 miles per tank.. ill run around naked
    Yeah, I have noticed that I can easily hit the 300 miles per tank mark with my basket and spare off the roof. I guess wind drag really does make that much of a difference.
    Hey, I updated the photo. You can see the WeatherPack now. Its kinda ugly, with all that tape and what not, but unless you are taller than your VX, you probably won't even see it.
    If you're taller than your VX, you need more lift & bigger tires...
    2000, Kaiser, 0134
    I'm not taller than my VX
    I'm waiting on 2 more lights to get here than I'll get to work. I'm installing Two Hella FF100, and Two Hella FF300, got them for a steal. Hopefully they do ok mounted on a roof rack as opposed to below the headlights.
  1. Rear fog and front fog lights wiring
    By David Wiltshire in forum Japanese Domestic Model (JDM) VXs
    Last Post: 07/07/2013, 01:40 AM
  2. Offroad Lights wiring issue
    Last Post: 05/22/2011, 02:22 PM
  3. PO's mod? Turn signal wiring split for window washer lights
    By Osteomata in forum VX Modifications...
    Last Post: 04/08/2009, 11:45 AM
  4. ? to those that have lights on their roof racks
    By VX-157 in forum VX Talk...
    Last Post: 04/01/2009, 11:11 PM
  5. Question about the wiring harness for fog lights
    By Arachnid J in forum VX Troubleshooting...
    Last Post: 06/26/2005, 08:31 AM
