CRAP......what have i done?????
ok, so i finally have some time where i can do some over due maint. on the truck. the first thing, (and easiest, by the way) i want to do is grease the u joints, and shaft. so i get things ready, mobil one grease, new pistol grease gun, put the nozzle on the zerk on the frontermost u-joint, grease the thing up, go to pull the nozzle off, and **snap** the zerk broke off. flush with the u-joint "housing"
any encouraging words, or last rites that could be offered? i am thinking of a small screw driver "jammed in there" delicatly, and see if i cant turn it out of there. or maybe screw ectrator? but worried about metal shavings getting in there too.
am i going to have to tear this thing out of there, and do it on the bench???
thank you all in advance, for all of your amazing input and banter
david
IndianaVX
also, is there a stainless steel zerk avalable? is there a specific zerk i can ask for. I think ive lost my vx cd in all the water weve had, i have the top part of the zerk, but not the threaded end, which is still in ujoint. are all zerk threads the same size????
thanks again for the help, as always,
david
