Results 1 to 15 of 26
Thread: Quick Help!! Cv Joint Boot Bands - How...
    2000, Kaiser, 0134
    How do I tighten and crimp these bands without the banding tool?
    I can get it tight supporting the band loop with a screwdriver while pulling with pliers but I don't know how to crimp it after.
    Please help I'm all torn down and it's dark
    Richie
    2000, Kaiser, 0134
    decided to just slip the boots on, then go get the tool in the morning...
    Is it ok to mix different Greases together? I think I need more grease (better safe than sorry)
    I have grease I use for my zerks Synthetic... Thinking of squirting some if it in...
    2000, Kaiser, 0134
    http://www.harborfreight.com/cpi/cta...emnumber=47288
    Will that tool ratchet and crimp a CV boot band?
    Quote Originally Posted by taylorRichie View Post
    NO...that is for banding together big heavies...like a bunk of 2x4's etc.
    The tool that came with the Mec-A-Tec kit is about the size of a manual can opener.
    Even being that small, it's hard to manipulate in the tighter areas.
    2000, Kaiser, 0134
    I found details on grease: http://www.mindconnection.com/librar...easecompat.htm
    And i'll just see if checker has the tool designed for it, and more of the same grease
    Said and done, I'll probably be into the repair ~3 hoursish It's really not too bad... And if these last me a year or two I'll be prepared with some mecatecs.
    2001, Ebony Black, 1153
    My mecatech lasted one day.......
    I just installed them on friday and as I was finishing up everything I noticed that the inner driver's side boot had a pin hole sized tear in it. I did not remember hitting it with a screwdriver or anything, I thought I looked it over pretty good before putting them on, oh well. Even just driving down the road slung grease all over down there with 0 miles on it. Next weekend maybe I will replace the boot that already had a tear before I drove it at all. The outer dorman is still holding strong though. Has anyone bought the factory boots? How much are they? That is what I am going to try next I think.
    Arrow
    IIRC, CV grease has a different spec. than bearing/chassis grease. Check into it further before mixing the two.
  1. CV Boot?
    By PapiGringo in forum General Tips...
    Last Post: 10/31/2014, 10:21 AM
  2. Another CV boot question
    By stangri in forum VX Talk...
    Last Post: 01/23/2012, 01:26 AM
  3. CV boot
    By Exclamation in forum VX Troubleshooting...
    Last Post: 11/21/2011, 09:17 PM
  4. UK CV Boot supplier?
    By voyeur in forum United Kingdom Special Topics
    Last Post: 04/25/2011, 10:32 AM
  5. VX CV Joint Boot Repair using MecaTech kit
    By johnnyapollo in forum General Tips...
    Last Post: 08/26/2009, 09:26 AM
