Results 1 to 7 of 7
Thread: perfect opportunity
    Jun 2007
    2001, Proton
    perfect opportunity
    to show your knowledge and make fujn of me for posting a stupid question. Where are the sparkplugs? I see 6 orange pieces on top of the manifolds that each have 2 screws. Are these hiding the plugs, Any special needs to replace Id rather be ridiculed here that go through the hassole of removing those in 120 degree weather only to find out they do not hide the plugs or other parts are needed.
    Well, now that you took all the fun out of it...
    Those orange things are individual coil packs, instead of a distributor, the CPU tells each one to fire.
    They extend through the valve cover to the spark plug. ( about 4-6 inches, can't remember)
    I agree....
    as per....
    All good now...
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    More importantly, those plugs are buried in the engine and you almost have to use a spark plug socket to get them out. If your toolkit has this socket, it will be seperated from the rest and have a soft rubber part inside to prevent the ceramic part of the plug from being damaged. If your kit doesn't have one, you may want to use a telescoping magnetic retriever to get the plugs in and out.
    2001, Dragon Green, 1342
    It simple, but you can also cause yourself a heck of alot of heartache and agro if you over torque them. The proper torque for the coil pack is 35 lb in and the spark plug is 13 lb ft. And remember to use a anti-seize grease on the threads. I did the torque in bold type so that you can see the difference. (There is 12 lb in, in 1 lb ft.)
    Jun 2007
    2001, Proton
    Talking Thanks
    I guess the best tool here is a checkbook
    Yeah, the back right plug is a serious WHORE to get at.
  1. Tod Perfect Timing To Fail!! Help!
    By KISSMYAURA! in forum VX Troubleshooting...
    Last Post: 03/29/2012, 10:59 AM
  2. Perfect VX wheels
    By RabidPony in forum Wheels and Tires
    Last Post: 01/23/2012, 07:16 AM
  3. Photo-Shoot Opportunity for VX'ers!!!
    By Riff Raff in forum VX Talk...
    Last Post: 09/29/2011, 11:41 AM
  4. So I'm conflicted... May sell the VX. Unique opportunity
    By taylorRichie in forum Chit-Chat ...
    Last Post: 03/16/2010, 05:57 AM
  5. Shameless photo opportunity
    By Anita in forum VX Talk...
    Last Post: 03/29/2004, 08:41 AM
