Results 1 to 12 of 12
Thread: R1 Concepts Drilled/Slotted & Painted Calipers
    Jan 2008
    Greetings!
    Well, I was able to turn some wrenches last night / today and add some paint!
    I also repacked the wheel bearings, rotated the tires, replaced the cracked serpintine as well as recharged the AC. Got to do some good crawling around under the Dragon finally. Although it's rusty, everything looks good. No evidence of prior off road abuse. Crawling under the Dragon's rear, it looks like we have a 5 link suspension?
    I did have to replace the lower radiatior clamps on the front exhaust O2 sensor heat shields. I noticed the rear O2 sensors did not have shields? It actually looks like there used to be one on the driver's side (rusty weld points right below the O2 sensor) but it is gone. The passenger side rear O2 has no evidence of shield, but interestingly enough, there was a broken radiator clamp rattling around there. Wierd.
    Anyway, had alot of fun digging around the Dragon's guts.
    Here is a straight on shot of the R1 rotors & painted calipers, front & rear:
    3/4 view:
    And front / rear wheel installed:
    I did not have time (or dough) to get the OEM pads from Merlin...
    I found OEM replacement Raybestos Professionals for 80 bucks front & back. They seem to grab really well, but I am basing this on previous driving with rear pads pretty much gone...
    The fronts did look like they had been replaced recently, but the previous owner neglected to mention that to me a few months ago. I can't imagine why he did not do all 4 at the same time. Probably tired of spending dough on the Dragon, that's why he sold it to me!
    I am sure he never wrenched on it himself, so I probably just saved 600 bucks with all the work I did myself!
    Thanks to all here for the help and guidence.
    Best,
    Jun 2005
    01 Dragon Green VX 1286
    good appearance.. let us know how the pads holdup... to include..how much dust they produce.. I think that was one of the main issues with going OEM
    Jan 2008
    Thanks!
    From what I could garner, the problem was the thickness of "aftermarket" pads. I spoke with Merlin, and he told me the OEM's were ceramic, so I made sure the replacements were the same.
    Best,
    2000, Ebony, VX, 0370
    Thanked: 12
    snowtrooper,
    When I replaced my rotors and pads it seemed like my front pads had been replaced too. I know that they weren't and at almost 70k miles the front pads still had a LOT of life left in them. I don't know if this is due to the Isuzu composites in the pads, or if a lot of the braking on the VX is done by the rear (the rear pads where pretty worn), but it's good to know that the pads hold up so long.
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    This is a five link:
    Ours is a three link (shocks don't count, nor does the panhard bar)which is nonetheless extremely capable.
    Jan 2008
    Thanks for the diagram, Ascinder!
    The panhard bar is the one @ the top of the rear diff?
    Jan 2008
    snowtrooper,
    I heard that the ratio is something like 70% rear, so that would explain whay our fronts looked so new. I still think someone had been in my fron Dragon paws. There was a bushing/washer missing on the left side, and the diff covers looked beat up
    Best,
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    No, the panhard is what keeps the axle located side to side. It should be the horizontal/diagonal rod that goes across the top and just to the rear of the axle and to the frame. Not to be confused with the swaybar which is the one with the bends in it. The panhard doesn't count as a "link " on the suspension either, since four links have them too, plus their four links.
  1. Rust in calipers, etc
    By VXD959 in forum VX Talk...
    Last Post: 06/08/2013, 08:32 PM
  2. zinc drilled and slotted rotors
    By soggybottomboyz in forum VX Modifications...
    Last Post: 03/16/2011, 02:47 PM
  3. Cross Drilled or Slotted Rotors??
    By Lizardmen3477 in forum VX Modifications...
    Last Post: 08/27/2007, 06:24 AM
  4. Slotted rotors
    By Andrey in forum VX Talk...
    Last Post: 04/24/2006, 09:38 PM
  5. Drilled and Slotted Rotors ???
    By psychos2 in forum VX Talk...
    Last Post: 02/08/2005, 06:49 AM
