Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Thread: Sway Bar Removal
  1. #16
    1999, Ebony Black, VX, 1614
    People always think a car is more likely to roll over with the sway bars removed. But the laws of physics don't change, your center of gravity is still the same. Your body will roll more within the framework of the suspension (sway bars are more accurately called "anti-roll" bars), but you're not going to just flip over because those little bars are disconnected.
    I believe the "motion in the ocean" can help to push you over though.
    Think about when you push/pull someone out of a ditch (without a vx)...you rock the car back and forth until you can finally complete the push. Without sway bars, you take a couple back and forth bends and the momentum will be much greater without the sway bars.
  2. #17
    Oct 2003
    1995 Isuzu Trooper LS
    Strictly speaking, the momentum is the same either way, but it may carry a bit farther to each side. If you had a tall vehicle and a lot of weight up on the roof I could see a change in the COG, otherwise not so much, not enough to matter anyway.
    Out in Moab I disconnect my sway bars for the entire week...drive winding roads like hwy 313 to Canyonlands NP...you get used to the body roll. Aired down tires are a bigger menace to highway cornering than disconnected sway bars.
  3. #18
    I never felt the VX handled dangerously with either sway bar off and I don't ever see myself putting the rear bar back on. I just noticed the front had a lot of under steer that persuaded me to leave it on full time.
    Swede... I figured you weren't running a rear sway bar in Moab. We we're the only 2 Zus that had issues with unseating our coil springs. Too much flex
  4. #19
    Oct 2003
    Yep, I have disconnects for both sway bars...that was the first time I had lost a coil on this Trooper; I didn't know the Ranchos that came with it were long enough to allow that to happen. I now have OME shocks that are a bit shorter and so should retain the coils from here on out.
  5. #20
    May 2012
    2001 Iron Man,Vehicross,0814
    Yep, that's what I was referring to.
  6. #21
    My rear swaybar has been in 2 pieces for the past 18 months with no adverse affects. If there is any differences in handling it is very little.
  7. #22
    May 2012
    The defense rests its case.
  8. #23
    Quote Originally Posted by Maddawg View Post
    I'm surprised you haven't had understeer with the front sway bar removed. Maybe more noticable with bigger, wider tires?
    Possibly something to consider when you go bigger...
  9. #24
    May 2012
    Could be, my turning radius seems to be unaffected. I'll be putting on bigger tires with a wider stance wheel soon so I'll see how much of an effect it has. I'll let you know.
  10. #25
    May 2012
    Yes, the wider stance did affect my turning radius understandably.
  11. #26
    Jul 2009
    Drastically so??
    Vixer Fixer
  12. #27
    May 2012
    No, but enough that it is noticeable. I have a corner I turn every day that is approx 110 degrees. The wheel input I always used puts me a bit nto the oncoming lane. Not a big deal, I just have to crank the wheel a bit more. Not thrilled but I can live with it.
  1. disconnecting sway bar
    Last Post: 04/21/2008, 03:26 PM
  2. sway bar question
    By dstruction in forum VX Troubleshooting...
    Last Post: 06/25/2004, 10:00 PM
  3. sway bar question
    Last Post: 05/19/2004, 07:05 PM
  4. sway bar disconnects
    By BBVX in forum VX Talk...
    Last Post: 04/19/2004, 06:46 PM
  5. Sway Bar Diameter
    By jbregar in forum VX Talk...
    Last Post: 10/20/2003, 08:32 PM
